754 - I am interested in the weldless frame kit, also did you end up doing a version of the Gordon kit last year, I found a thread where you said you going to do it.
Old Scrambler - I had a search and found a picture of a frame that only has 1 very thick centre rail, and schematic from CMS that is only slightly different from the K frame so not sure which one is right.
my biggest hesitation with trying something like this is I have to fit the engine to check the clearances and measure it all up, then take out, make the mods, fit the engine, see where it needs tweaking, remove the engine, make adjustments, refit engine, if its good then I can get it all painted, and then fit the engine after all that. and all that is what I am trying to avoid.
