I'm replacing the triple-tree mounted hydraulic stop switch with a banjo bolt stop switch. Now I need to plug the hole the original switch was in.
What is the thread pitch/length of this hydraulic switch? I was thinking a stainless hex bolt with a crush washer would be a good plug.
Also, the reason I'm doing this is because I just bought new stainless brake lines, and this is a cheaper alternative than getting one whole new line.
ALSO
PO lost the "cruise control" bolt from the Right control switch. What is the thread size of this one? I checked cmsnl and the part is no longer available, nor do they have a size listed.
