Author Topic: CB 750 K1 GT New Pics with a new look  (Read 127189 times)
Re: Tweakin's Turd (K1)... Paint Done
« Reply #125 on: December 22, 2013, 07:31:00 AM »
Top shelf all the way. Tell your Guys to hurry up so we can see this thing together   :D
Offline tweakin
  • tear down
« Reply #126 on: December 22, 2013, 05:52:47 PM »
Got my sweet braised brake lines from member pampadori.  Great product, fast shipping and also included this awesome koozie that will be put to good use, cheers. ;D
« Reply #127 on: December 22, 2013, 05:58:01 PM »
Moving along nicely, love the Yamiya gear... ;)
Offline tweakin
  • tear down
« Reply #128 on: December 23, 2013, 06:58:20 AM »
Thanks for stopping by Retro.
« Reply #129 on: December 23, 2013, 11:59:27 AM »
Been lurking the whole time... ;)
Offline tweakin
  • tear down
« Reply #130 on: December 23, 2013, 02:33:32 PM »
Good, I was starting to get hurt feelings... :'(  Happy Holidays brother.
« Reply #131 on: December 23, 2013, 05:04:39 PM »
Same to you mate.... ;)
Offline CBcafeJunkie
  • 75 CB750F
« Reply #132 on: December 24, 2013, 05:36:58 AM »
Love the carbs man wish mine looked that nice.
Offline YogiBear
« Reply #133 on: December 29, 2013, 09:38:55 PM »
I'm subscribed. This looks amazing so far, Tweakin. The gauges,  I am impressed with how well you resurrected them.
1974 Honda CB750K4        1973 Honda CB500 Four
Offline tweakin
  • tear down
« Reply #134 on: December 31, 2013, 07:21:25 AM »
Thanks for checking out the build Yogi, more to come.
Offline tweakin
  • tear down
« Reply #135 on: December 31, 2013, 07:54:01 AM »
Built then painted the head yesterday.
     New guides
     Kibblewhite springs
     Kibblewhite black diamond valves
     Kibblewhite Ti retainers
     serdi valve job
     all new 6mm helicoils
     mild port and polish
Next on the list is to completely rebuild the oil pump, including Elan's new stopper and spring, new o rings including new shaft seal.  Man those shaft seals are a #$%* to remove.
« Reply #136 on: December 31, 2013, 08:02:06 AM »
Wow, that head looks better than new.
« Reply #137 on: December 31, 2013, 08:09:36 AM »
I'd say it better than new!
Offline nvr2old
« Reply #138 on: December 31, 2013, 10:05:37 AM »
I really enjoy seeing all the new stuff, tweakin'.  Man alive, you really do go top shelf. .  Your projects are wonders to behold.
'76 CB550F-'72 XL250-'82 MB5-'82 CX500 Turbo-'77 naked Goldwing-'75 CB400F cafe'-'79 Suzuki GS1000S..hey, it's a Wes Cooley..
Offline tweakin
  • tear down
« Reply #139 on: December 31, 2013, 12:53:32 PM »
Nothing to exciting to update on yet, but still moving forward.
Oil pump rebuild complete, primed and soaking in my oil bath until I complete the engine.
Oil lines rebuilt and polished up a bit.
Engine mounts and axles are polishing up pretty well, but still need a bit of work.  Also sound some new 10mm and 12mm fine thread 12 point nuts for the engine mounts.  Stainless and Black oxide.
« Reply #140 on: December 31, 2013, 01:53:46 PM »
Great work, as always, on that oil pump.  I like those bolts.
« Reply #141 on: December 31, 2013, 03:06:56 PM »
Nice work!  I had fun doing my oil pump w Elans kit.
Engine mounts, center stand, and kickstand are on my list of to-do's tonight.  I hope mine come out as nice.
Nice choice on the 12pt nuts.
« Reply #142 on: December 31, 2013, 06:54:14 PM »
The black oxide...keep lightly oiled, as you know, they rust easy otherwise and are a pita to clean up.  Wonder if silicone would protect them from rusting but keep the dirt buildup to a minimum?
Who did your head work? Mike R?
Was the head ported at all? I presume with the nice upgrades to top shelf merchandise you had some work done on the head to eek out more performance...
David
Offline tweakin
  • tear down
« Reply #143 on: December 31, 2013, 07:17:19 PM »
Yes, I know all about the issues with black oxide nuts and bolts.  The 10mm are stainless but the 12mm didn't come in stainless.  Although they are "supposed" to not have the typical issues, they will be shot with a light coat of clearcoat once installed.
Since I already have the wonderful JMR stage 4 head in the 915 i wanted something a bit tamer for this head, I also wanted to do all the work myself.  I did a mild port, clean up of castings and matched the intakes myself for this 836. I was stoked when my machine shop was impressed with my work.  No need for two screaming 750...  I just want a strong running 836 this time around, should move along good.
David
« Reply #144 on: December 31, 2013, 07:37:26 PM »
David
Be very careful using silicone on the black oxide, most silicone is acidic and will promote rust, there are non acidic versions that would work, ever see all the dodgy  leaky windscreens "fixed up" with silicone.? most just about fell out due to rust not long after... ;)
Offline tweakin
  • tear down
« Reply #145 on: January 01, 2014, 06:57:52 AM »
Yes RR, no silicone here.  The nuts are high quality ARP chromoly nuts, but will probably hit them with a shot of clear to be safe.
David
Offline SF
  • I burn gas very well
« Reply #146 on: January 01, 2014, 10:27:12 AM »
Top notch Tweakin, are you going to use lock washers with the 12 points? Just my 2cents but you should hit the exposed ends of the bolts with a file/polisher for nice clean look
92 wr250 sold
98 zx6r sold
04 zx10r
73 cb350 twin
75 cb550f
75 cb550f
72 r5c
rgid springer bobber project
Offline tweakin
  • tear down
« Reply #147 on: January 01, 2014, 10:31:27 AM »
Yes lock washers for sure and yes the ends of the bolts have already been taken care of. ;)
« Reply #148 on: January 01, 2014, 12:05:14 PM »
"Top Notch Tweakin", sounds like you have a new name?
Offline MoMo
  • Ride like you're invisible
« Reply #149 on: January 01, 2014, 12:50:03 PM »
you mean TNT?   ...Larry
