Author Topic: CB 750 K1 GT New Pics with a new look  (Read 125625 times)
Offline tweakin
  • tear down
Re: CB 750 K1 GT FINISHED Pics
« Reply #400 on: March 05, 2014, 05:18:28 AM »
Thank Ted, Love the seat.  Also appreciate all the work you guys do at CCC to make parts available for these old bikes.
As usual, brilliant work, Tweakin! What a fitting place for one of our seats! Thanks for your support of our efforts! Very impressive resuscitation of an old CB that needed a lotta lovin'! RR
Thanks for checking out my build gj.
dang - she's a beauty!
« Last Edit: March 05, 2014, 05:21:04 AM by tweakin »
Offline Bru-tom
« Reply #401 on: March 05, 2014, 11:00:27 AM »
wow, stunner of a bike man!!! ;D No shortcuts taken, great job!
« Last Edit: March 05, 2014, 11:02:52 AM by Bru-tom »
« Reply #402 on: March 05, 2014, 12:00:13 PM »
You got that right, Bru-tom.  If Tige had finished a week earlier, he would have been the hands down winner of BOTM March, and blown us both out of the water.
Offline tweakin
  • tear down
« Reply #403 on: March 06, 2014, 06:08:44 AM »
Thanks Bru-tom!  Once the ball starts rolling on my builds I have a difficult time holding back. ::)
Offline Bru-tom
« Reply #404 on: March 06, 2014, 07:28:02 AM »
speak for yourself brother :P hahahaha everything happens for a reason ;)
i never thought my work would ever have been recognized anyway, so im already a winner ;D
i feel the same way, mine took 6 months of hard work. and a good few to save up before i jumped into it ;D I would like to do a resto for my next build, im getting a xt500 next.
Offline greenjeans
  • 1972 CB750K2
« Reply #405 on: March 06, 2014, 02:59:29 PM »
Did I just miss what you bored that motor to ?     Also, what cam ?    And, how doe those GP pipes sound ?  I have a set hanging in my garage waiting
for my lazy arse to finish my latest.   Can't believe that I'm just now reading through this thread (again).
Beautiful and tasteful.  Just like a classy gold digger.
Offline tweakin
  • tear down
« Reply #406 on: March 06, 2014, 06:30:15 PM »
Thanks for the props on the build.
Engine
836 JE pistons
63A cam
Head: Mild port and deck, oversized intake and standard size exhaust kibblewhite valves
kibblewhite HD valve springs with Ti retainers
MLS gasket
Pamco ignition with 2.2ohm coils
I love the sound of the pipe, here is the sound clip from initial start up.
1971 cb750 K1 JDM
Offline David B
« Reply #407 on: March 06, 2014, 07:47:59 PM »
Bike looks and sounds fantastic, Tweakin. All the accolades you're receiving are well earned.
DB
DB
Offline tweakin
  • tear down
« Reply #408 on: March 07, 2014, 05:50:32 AM »
Thanks for taking the time to check out my build David, I appreciate the comments.
DB
« Reply #409 on: March 10, 2014, 04:39:38 AM »
Tweakin I may have missed this in your thread but what bar end mirrors are you using and would you recommend them?
thanks
Andy
Offline atm cycles
« Reply #410 on: March 10, 2014, 05:06:23 AM »
Tweakin spent a lazy Sunday reading all your builds. Incredible !!!! Seeing your attention to detail is meds for my ADD.
Offline tweakin
  • tear down
« Reply #411 on: March 10, 2014, 05:43:32 AM »
thanks
Andy
I am running CRG bar end mirrors.  I have run CRGs on multiple bikes and could not be happier.  I have tried less expensive options but always go back to them.
Offline stuartni
« Reply #412 on: March 10, 2014, 08:20:22 AM »
bike turned out amazing very nice work  8)
« Reply #413 on: March 10, 2014, 10:17:58 AM »
Thank you for the info and feedback!
Offline tweakin
  • tear down
« Reply #414 on: March 11, 2014, 03:16:28 AM »
You bet.  If you decide to go with the CRG's, decide on the ones you want then shop around.  I found my last set including adapters on Amazon for a decent price.
Offline brandEn
« Reply #415 on: March 11, 2014, 09:10:51 AM »
When you did your dual disc conversion did you modify/remove material from the right fork lower caliper mount?
Offline tweakin
  • tear down
« Reply #416 on: March 14, 2014, 06:51:41 AM »
I did not B, but still might revisit this.  Everything lined up nicely but I might modify the lower mount to gain a bit more clearance between the caliper and spokes.
Offline Trad
« Reply #417 on: March 14, 2014, 06:56:32 AM »
Sounds fantastic.
74 CB550 Build: NOS-GUTTED-OEMplus-HOLDTRUE
http://forums.sohc4.net/index.php/topic,130575.0.html
Offline Godffery
  • Godffery's Garage
« Reply #418 on: March 14, 2014, 01:55:49 PM »
There is a slight problem with doing that; it causes the brake pads to contact the rotor at an angle.  To address this issue, I have modified the pads with a 36 grit sanding block to match the new angle.
They will eventually wear in by themselves but it takes a while and may cause the outer pad to stick in the caliper and WILL cause the brake lever to feel spongy for a while.
Offline tweakin
  • tear down
« Reply #419 on: March 14, 2014, 09:33:33 PM »
Thanks for the heads up Godffery, good to know.
« Last Edit: March 16, 2014, 07:31:57 AM by tweakin »
Offline tweakin
  • tear down
« Reply #420 on: March 29, 2014, 07:52:57 AM »
1 step forward and 2 steps back.   :'(
Get the carbs pretty much sorted and bike running excellent only to find the F'n JDM unicorn triple tree is cracked!!!  I started weeping when I saw this, but then grabbed a fresh IPA to help ease the pain.  Yes, I did have the correct D - washers installed and No, I did not use supper strength when torquing down the pinch bolts...  Such a major downer!
Good thing is our friends at Motorcycle Yamiya had one more aluminum re-pop in stock.  No more worries about the fragile unobtanium top tree.  Plan is to have the old tree welded up and use it in a small art project.
« Last Edit: March 29, 2014, 07:55:55 AM by tweakin »
« Reply #421 on: March 29, 2014, 08:14:05 AM »
I know that feeling all too well.
« Reply #422 on: March 29, 2014, 09:11:00 AM »
ouch, sorry to hear. So, no need for D washers on the repop triple?
Offline tweakin
  • tear down
« Reply #423 on: March 29, 2014, 09:17:42 AM »
Yes Stev-o, sucks.  Correct, no need for the D washers on the new triple since its aluminum.
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #424 on: March 29, 2014, 10:43:34 AM »
That really sucks Tige.
Glad to hear you had a well stocked medicine fridge.
