Author Topic: Simple question - Cam chain tensioner blades.  (Read 4314 times)
Offline Dimitri13
  • 1974 CB550K
« on: November 15, 2013, 01:11:43 AM »
Just a simple question: should these blades be replaced?
Re: Simple question - Cam chain tensioner blades.
« Reply #1 on: November 15, 2013, 01:15:32 AM »
if you can see cracks and can pick bits off theyll be ready for replacement,if they are the factory ones id replace them,ive reused plenty though.
Wobbly
« Reply #2 on: November 15, 2013, 01:55:55 AM »
Considering that you are already there, and that they are still available and thus very reasonably priced, I say: by all means--replace them. And while you are at it, spend another ten bucks on a new cam chain roller unless it has been recently replaced. Rubber doesn't do so good with the years.
« Reply #3 on: November 15, 2013, 02:03:52 AM »
no rollers in 500/550s.
Wobbly
« Reply #4 on: November 15, 2013, 02:38:12 AM »
Be default, I always assume CB 750  :)
« Reply #5 on: November 15, 2013, 02:43:56 AM »
ha!yeah its 500/550s for me by default.
Offline Dimitri13
  • 1974 CB550K
« Reply #6 on: November 15, 2013, 10:07:55 AM »
Thanks guys. I'll be replacing them. Might just get the whole tensioner assembly since I kinda bent mine up a bit.
« Reply #7 on: November 15, 2013, 10:23:43 AM »
one too many PBR's while wrenching.
happens to the best of us  ;D
Offline Dimitri13
  • 1974 CB550K
« Reply #8 on: November 15, 2013, 12:59:49 PM »
Lol, that was before I started drinking.
« Reply #9 on: November 15, 2013, 01:01:16 PM »
you know all about making sure the bottom tang of the tensioner locates into its little slot in the lower case half?
Offline Dimitri13
  • 1974 CB550K
« Reply #10 on: November 15, 2013, 01:50:39 PM »
I see that's where it goes, but how do I make sure it seats?
« Reply #11 on: November 15, 2013, 02:37:43 PM »
i remove the pan to be sure,its hard to spot it properly from above even with a good flash light,if your fully rebuilding an engine the pan would be off anyway?
Offline Dimitri13
  • 1974 CB550K
« Reply #12 on: November 15, 2013, 07:20:18 PM »
Yeah the pan is off, but the engine is on the bench, so I have to lift it up to see.
« Reply #13 on: November 15, 2013, 07:46:47 PM »
heres an engine i pulled down only to find this?sheesh,i wouldnt be surprised if even back in the day a dealership could foul this up.
Offline Dimitri13
  • 1974 CB550K
« Reply #14 on: November 17, 2013, 02:24:21 AM »
I know cmsnl and dss have all the tensioner pieces, but is there anywhere less expensive?
And since we're on the subject, what problems does a worn tensioner cause?
« Reply #15 on: November 17, 2013, 11:42:40 AM »
it wont tension the chain enough.
Offline Dimitri13
  • 1974 CB550K
« Reply #16 on: November 17, 2013, 04:56:47 PM »
Thanks dave.........
Better question: what problems are caused by a loose cam chain?
« Reply #17 on: November 17, 2013, 09:40:19 PM »
floppy whippy chain flailing about,on 750s itll chew into the tunnel,never seen it on a 500/550 yet but it could.
Offline Bodi
« Reply #18 on: November 18, 2013, 08:09:21 PM »
loose cam chain is nasty noisy, cam timing gets a bit wonky (not really a problem); loose enough and it can skip on a sprocket - performance is hurt by one tooth out and more will eventually have the valves hitting the pistons; the blades wear fast and can be chipped by the whipping chain; I think all the "four" engines have the main oil gallery across the engine in front of the crank and a loose chain can rub on the inside of the case where the gallery is - if it wears through you have oil pressure drop/loss; on the 350/400 engines a loose chain damages the adjuster horseshoe pivot making it lock up so the cam chain tension is unadjustable - I can't say for sure that a loose chain causes chain failure, but the only four I've seen with a snapped cam chain was a 350F with its adjuster locked up by this damage. After a cam chain breaks, it's best to look for a good used engine. The carnage in the cylinders is prohibitively expensive to fix.
Offline Dimitri13
  • 1974 CB550K
« Reply #19 on: November 18, 2013, 09:01:29 PM »
Ordered new blades from DSS. $150 goes bye bye.
Offline Tews19
  • I am no
« Reply #20 on: November 18, 2013, 09:53:35 PM »
Glad I checked this out. Dimitri, I noticed the cracks in yours so I went to check mine out. The smaller blade got a knick and that will need to be replaced on mine. The top blade with the cam tensioner nut on it looks good though
1970 Honda CB750 survivor.
Offline DustyRags
  • I'm not skilled, I'm just a
  • Just try it and see what happens
« Reply #21 on: November 19, 2013, 11:12:36 AM »
My 550 started chewing into the cam tunnel, but wasn't too bad. Place install the tensioner in the jugs with the jugs a few inches off the case, and then drop the whole assembly down together. Once the jugs are in, you can't get the tensioner in correctly.
1976 CB550K- sold
2005 Kawasaki Vulcan 500- sold
2000 CB750 Nighthawk - sold
1975 XL350 - crashed
2004 Suzuki Vstrom 650 - sold
Offline Dimitri13
  • 1974 CB550K
« Reply #22 on: November 19, 2013, 02:35:02 PM »
I was able to get the tensioner in with the just mostly on (about 1/4" up, enough to get the small blade in).
The big tensioner had cracks at both ends, enough so that I could break it with little effort.
