Geez mate, after 38 years you've got a missing nut, a couple of loose bolts and a wonky speedo cable, would you like some cheese with your whine?
Sure Terry, that bike is 38 years old ! But that bike is not "in perfect condition, ready to ride, 1 owner only, well maintained" as promised
It has been tinkered by an incapable mechanic as you can see on the following pictures
Many thanks Dream750 for your help, it seems that the rubber holder is the same than on CB450 and I have some new refab in stock. On your parts-list picture I find that the part #5 is missing also, named "stay, diode" on CMSNL parts-list.
The first surprises gave a good idea of what I could find later ! The engine was resprayed with the spark plugs in place, so they were painted too :
Have you ever seen such idiot fuel pipes ? Leaks on each "T" ...
Handlebar is twisted on left side :
Alternator, oil pressure and neutral were disconnected :
And the epic wire connection in the head light, 4 cables disconnected and 1 cut, paper adhesive tape and strange orange/blue cables for the winkers :
What I found under the adhesive tape :
Some work on the wire harness during next days
