It's been a while since this was posted, so apologies for taking so long. To review, in a nutshell, my idea was to use an aftermarket alarm module to activate my bikes stock horn, instead of using the wimpy buzzer that came with the alarm kit. I'll post the diagram, and hope you all will bear with me as I grope thru this bright idea.
The diagram below shows the use of two (2) SPDT relays. (Green arrows) point to relays, (RED arrows) point to triggers. The triggers are arranged in series, and TAKE THE PLACE of the alarm buzzer in that circuit. If the alarm is ever activated, the TRIGGERS of the relays
switch on and off, as commanded by the module. The load carrying portion of both relays are arranged in such a manner that power and ground are supplied to the bikes horn (on-off beep) even when the ignition is turned off and key is removed.
I think what I have will work.....kinda..
The only thing I haven't yet figured out is current draw rating of the old buzzer
that I removed. Does the old buzzer need to be hooked up and functioning as
a working component? And, from there, do amp drop test? Or, can I get by with substituting an ammeter, IN PLACE OF the buzzer, in series, activating the alarm and and read currentflow thru the meter?..I will stop here and wait.opinions/theories?........Thanks for your thoughts, and I'll stay with it this time.
