Author Topic: oil leaking out of #2 exhaust  (Read 803 times)
Offline Luckystrike
« on: November 16, 2013, 06:01:14 PM »
Much to my dissmay I found oil pouring from my exhaust. Its fresh oil. Could this be a valve seal? I replaced them a year ago and havent driven it yet. Or could it be something else?
Thanks
Offline scharny61
Re: oil leaking out of #2 exhaust
« Reply #1 on: November 19, 2013, 12:11:46 AM »
do you mean when it's running or just sitting there? If the oil is clean and fresh, I'm thinking it hasn't gone through the combustion chamber. Could be a hole in the puck seal found under the cam holders. I think they may lead somehow into the pipes?????
Offline martin99
  • UK Based, Non-
  • Adventure before Dementia
« Reply #2 on: November 19, 2013, 12:59:45 PM »
What kind of exhaust have you got? Sure it's not leaking from the engine somewhere and dripping on to the collector? Unless you've got straight-thru's, most silencers are angled upwards - they'd need to be a lot of oil in there for it to pour out the end :-\
Build threads:
1977 CB750 F2
1958 Norton Model 99
« Reply #3 on: November 19, 2013, 02:20:23 PM »
What bike?! Out the exhaust pipe? ETC? Could be numerous things. You really should provide details if you're needing help as we can not read minds.
Offline Luckystrike
« Reply #4 on: November 24, 2013, 11:00:14 AM »
It is a cb500. Ive had it for over a year.i havent ridden it but just started it.  I took a peak inside and found one of the pucks had come loose and the cam cover gasket was pinched.
