Author Topic: 1980 CM400A Hard-tail Build.  (Read 1487 times)
Offline Lostboy Steve
« on: November 19, 2013, 08:44:00 AM »
I purchased a 1980 Cm400A for $200.00. No title no keys. I had a title recovered and then switched all the locks. I was originally going to build it for my wife to learn, but lets face it, she's not interested. This motorcycle is 100% factory. Everything was there including the mouse nest that used to be an airfilter. I bought a (already cut) frame so I can keep the original one uncut. I rebuilt the carbs and changed the oil. She fired right up. I am now turning this into a very classic style hardtail. Factoring in the 400a engine has made me believe that I can literally run a single lever for front brakes and have a VERY minimalistic build. Se here it begins. Sitting atop my newly build work table waiting to get striped. The color of the powder-coat on the wheels is being worked into the whole picture. I had originally intended to go with an off white, texture powder and an emerald metallic paint which i am carrying over to the new direction.
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
Offline iron_worker
Re: 1980 CM400A Hard-tail Build.
« Reply #1 on: November 19, 2013, 08:48:44 AM »
So combined braking on a single lever? Running discs front and rear? Do you think you'll need some sort of proportioning valve? Two separate MCs activated by one lever?
I'm interested.
IW
« Reply #2 on: November 19, 2013, 09:27:09 AM »
I'm interested.
IW
Well I'm thinking of keeping a rear brake pedal. The "shifter" is most likely going to be of the jockey variety. The biggest hurdle I can see with braking will be the parking brake. From the factory this bike has a parking brake.
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
