Avoid the Daiichi brand. They have a tiny little "clover"-like emblem stamped on many of them. They are poor quality, don't time up properly, and the contacts have thin tungsten that burns quickly (unless used with my Ignition - but that won't fix the timing issue). The condensors used to be OK, but lately have been reported to be shorting out, which is curious. This means they don't have enough insulation rating, so the 400v+ kickback from the coils is eating them up.
Honda sells the whole plate, pre-assembled and timed, from TEC (Dimitri's post ^^). Those often drop in, time one side (1-4), the other is done already. Very nice! If you have the option, go to Ace Hardware and get 3 of their 5x16mm stainless bolts with washers to replace the screws for the timing plate. This combination makes things a lot easier during setup, and they don't strip out later on.
