Author Topic: am I missing something?  (Read 667 times)
Offline Carver
« on: November 19, 2013, 09:24:09 PM »
Alright, I got new gauges, the 2.5” from dcc, and im trying to wire them in. the diagram I'm looking at shows that the positive end gOes in to the brown white Connecter, did that, but then it shows the - going in to a green connecter, well I can't seem to find it.  I think its supposed to attach to one coming from the headlight, but a green brown comes out of that and the other cable goes to the side of the headlight. Am I missing something here or do I need to wire in some kind of ground?
Cb 750 k3
Cb 450 dohc k4
Offline MoMo
  • Ride like you're invisible
Re: am I missing something?
« Reply #1 on: November 19, 2013, 10:34:36 PM »
I see a 4 gang green connector for ground...Larry
Offline Carver
« Reply #2 on: November 19, 2013, 10:56:58 PM »
I tried plugging it in to both of the green connectors, I think something migjt be wrong with the circuit. Ill have to do some tests when im not working
Cb 750 k3
Cb 450 dohc k4
Offline MoMo
« Reply #3 on: November 20, 2013, 12:32:22 AM »
First make sure the gauge lights work, you can hook the wires directly to a battery. If  the light comes on then, you are either missing 12v at the brown/white wire or have a bad ground. ...Lary
Offline Vinhead1957
« Reply #4 on: November 20, 2013, 12:21:11 PM »
Get a good schematic and meter brown white wire indicates switched power .  Light switch is involved as well as the key switch.
