Author Topic: Name that part?  (Read 1151 times)
Offline fooque
Name that part?
« on: November 20, 2013, 11:57:55 AM »
CB350F engine is out of the frame!  Thanks for all the help!  So I took the oil pan off the bottom and I found these three little metal thingies rattling around in the bottom.  Any idea what they are?
Offline CycleRanger
  • No comment about being an
Re: Name that part?
« Reply #1 on: November 20, 2013, 01:18:26 PM »
No clue.
Can you get a closer shot with something for scale?
Offline brooze72
Re: Name that part?
« Reply #2 on: November 20, 2013, 02:06:51 PM »
are they a metal that is magnetic?
1972 CB500K1 - restored rider
1981 CB650C - new project
Offline fooque
Re: Name that part?
« Reply #3 on: November 21, 2013, 03:50:26 PM »
Not magnetic.  There were also two small springs in oil pan.  Here's a pic with a penny beside them for a sense of scale.
Offline nccb
  • 1974 CB750 Four
Re: Name that part?
« Reply #4 on: November 21, 2013, 04:31:47 PM »
for a second I thought grease fittings, but I have no clue now.
Offline fooque
Re: Name that part?
« Reply #5 on: November 22, 2013, 05:33:36 AM »
Well, I figured out what they are.  I read through the entire PDF of the manual, and they are part of the primary shaft assembly.  They are the caps that fit into the rollers.  It looks like the springs provide some kind of tension, but I don't know for what...
I'm a total noob, so I have no idea what the rollers on the primary shaft does.  Any help there?  Should I just start a new thread?  Here's the pic.
Re: Name that part?
« Reply #6 on: November 22, 2013, 05:45:48 AM »
Starter clutch?
Re: Name that part?
« Reply #7 on: November 22, 2013, 07:27:07 AM »
Yup, part of the starter sprague clutch
Offline fooque
Re: Name that part?
« Reply #8 on: November 22, 2013, 09:01:47 AM »
Thanks, guys!
Offline iron_worker
Re: Name that part?
« Reply #9 on: November 22, 2013, 10:08:07 AM »
Yep. Allows the starter to drive the crank but not the other way around ... which would be bad. ha
IW
