Author Topic: Bike scrap yard sell. Hot head! I should have bought it?  (Read 6936 times)
« on: November 22, 2013, 04:43:57 am »
I visited a scrap yard today when they had got CB750 parts. Ported heads and cylinders
I went there to buy a head.  Too extreme for me. One had welded inlet ports, inside 36mm outer >40mm) Suzuki 1100 carb boots to be used.  Did not buy cylinder with fresh 67.5 mm pistons and rings or another one with 836.
Found another head with moderate porting for $175 plus CB900 con rods. I guess I'll regret not buying the extreme one when this kind of stuff is seldom seen for sale. And the fresh cylinder with 67,5 mm pistons with rings. No vertical ring lash or other damages. I saw carb project of about $1000-1500 plus a crank case job for the bigger cylinders.
Re: Bike scrap yard sell. Hot head! I should have bought it?
« Reply #1 on: November 22, 2013, 05:00:43 am »
I'd say that head is a good start......it needs a lot more work to live up to its potential.
« Reply #2 on: November 22, 2013, 05:39:30 am »
This kind of ports will work for racing only, bad response on low, right?
« Reply #3 on: November 22, 2013, 07:04:17 am »
Actually a lot of material can be removed from the roof PeWe....it woul pick up some good CFM.
  • Moderator
« Reply #4 on: November 22, 2013, 07:11:14 am »
I think my ports were bigger than that Mike and mine could be ridden on the street if one wanted to.
Sam. ;)
Offline turboguzzi
« Reply #5 on: November 22, 2013, 08:51:11 am »
pee wee, i am no expert on CB750's but if it helps you to know, my 810 gpz that makes 90 rear wheel horsepower has ports that are only 29 mm, would open them up to 31 if i had a carb set to match, but not more, so I would say that 36mm is very much on the large side....  IMHO of course (regardless of the fact that you could remove material from the roof like mike says).
Sam, "could be ridden on the street if one wanted to" can be interpreted in many ways.... like from how low could you open the throttle?
« Reply #6 on: November 22, 2013, 12:34:39 pm »
I did not leave empty handed....
I could not resist another cheap head. The port job might be a little bit too inspired...?
Seats for original valves 32/28. EX valve guides need to be replaced.
CB900 con rods 1.5mm longer that might be useful. Maybe with my old AF 836 pistons.
Only 32mm IN valves give room for 1,5mm higher lift of the piston. Only 0.5mm closer ::)
« Last Edit: November 22, 2013, 12:49:55 pm by PeWe »
Offline dragracer
  • CB750F Dragbike
« Reply #7 on: November 22, 2013, 01:56:30 pm »
Crap, i wish i had that extreme head for my F model. Just my luck its not here in the states.
« Reply #8 on: November 22, 2013, 03:48:39 pm »
Crap....you could put on small Lectrons Frank. ;D
« Reply #9 on: November 22, 2013, 04:00:30 pm »
UPS?!
« Reply #10 on: November 22, 2013, 04:29:15 pm »
UPS?!
USPS if it is coming from Europe Jerry ;)
« Last Edit: November 23, 2013, 08:42:11 am by MRieck »
Offline dragracer
  • CB750F Dragbike
« Reply #11 on: November 22, 2013, 06:45:26 pm »
Yeap, some 34's might work just right. I'd better stick with what i've got for now. You guys on this forum will make a person go broke on these old bikes stepping them up and we'd still not be fast enough to beat the newer bikes straight off the showroom floor. lol
« Reply #12 on: November 23, 2013, 01:03:32 pm »
I went back for the cylinder, 67,5mm (900cc). I got a K2 -1972 case in the deal, dirty but no visible damage. A new project is started: head with valves-cylinder-case-CB900 rods. Some parts left :D
-One question though. Who made the pistons?
EDIT: I found answer here http://www.satanicmechanic.org/bigbore.shtml
Henry Abe  "marked HAINST"
One more thing, the head with huge welded inlet ports still available.
« Last Edit: November 23, 2013, 01:30:10 pm by PeWe »
« Reply #13 on: November 23, 2013, 01:40:08 pm »
 Henry Abe INDUSTRIES is Hainst
« Last Edit: November 23, 2013, 05:31:35 pm by 754 »
Offline dragracer
  • CB750F Dragbike
« Reply #14 on: November 23, 2013, 05:26:42 pm »
PeWe, what were they asking for the head?? (US dollars please). This thing has my interest up now.
Let me know please.
« Reply #15 on: November 24, 2013, 01:35:41 am »
Let me know please.
$410 US  (2700 SEK) with valves and alu retainers. I think that old carb boots will follow if you ask for it.
I'll PM you the email address to the bike scrap yard, well-known here.
Offline POPS 911
DRAGRACER - FRANK
« Reply #16 on: November 24, 2013, 07:06:08 am »
I have a BRAND NEW SET IN THE BOX 34MM LECTRONS. Can send to you and you can pay if they are what you need. Was given to me as part payment on a stroker BUSA motor.
POPS BK911
« Reply #17 on: November 24, 2013, 08:08:20 am »
There you go Frank. I could clean that head up a bit too. ;D ;D
Offline dragracer
  • CB750F Dragbike
« Reply #18 on: November 24, 2013, 08:19:10 am »
Let me know please.
Thanks PeWe. Please send me details on the scrap yard. I'll see what they can tell me.
Mike, looks like we might have another project.
Pops, PM me info on the carbs and a price.
Offline Jim F
  • go baby go
« Reply #19 on: November 24, 2013, 08:34:00 am »
you don't need to tell me about spending money Frank
you would have a heart attack if I told you how much i had in my turbo
and I try not to think about it
2002 RC51 1000 (SP2)
1983 GS1100EC Suzuki
1992 KTM500 2 stroke
1975 CB750/836 Honda
1978 GS750/840 Suzuki
Offline dragracer
  • CB750F Dragbike
« Reply #20 on: November 24, 2013, 08:44:46 am »
Its too bad we can't sell our projects to recoup the exact amount of money we've put into them.
« Reply #21 on: November 24, 2013, 11:20:17 am »
We'd all be retired kicking it in the Caribbean right now Frank.  ;D
« Reply #22 on: November 24, 2013, 11:35:56 am »
This kind of insanity is passion! Very wonderful feeling upgrading/tuning. Interest we can discuss here, learning more and help others. Driving too is fun. I have not done it yet, I have to wait for spring.
I have spent some on my bike the last 2 years bringing it back to life and restore the changes during the 80's that were so fun then. Horrible today!
So far about double amount of $$$ I planned 2 years ago (double time as well). Upgrades and repair old rotten parts. Only super crank with rods missing...  :(
Buying a new tank with side covers in correct color from yamiya750.com was not possible 1 year ago, now planning WHEN to put in basket, not IF!
I have now got parts that need more parts.. head-cyl-rods, K2 crank case with B BBBB as my K6 running engine, very useful when swapping cranks !
When engine is completed it will need a frame or a complete bike....
I have done it again! Same as the expensive big repair/upgrade 1983/84. When I was finish, money spent was enough for a new Kawasaki 1000J. But my bike had no problem to keep up with these bikes.
Today I have a CB750 I can spend money on, again! Kawasaki 1000J 1983-84 model is not that popular.
« Last Edit: November 24, 2013, 11:38:28 am by PeWe »
Offline Jim F
  • go baby go
« Reply #23 on: November 26, 2013, 08:14:36 am »
Amen Frank, but it most diffidently a passion, Just dont let the wife's start to snoop around this forum
« Reply #24 on: November 26, 2013, 10:08:41 am »
"Its too bad we can't sell our projects to recoup the exact amount of money we've put into them. "
That's the new "Making Idiots Whole" Government program.
Now if they can only get the website up, we can enroll.   :D
