Author Topic: Blowing fuses  (Read 1151 times)
Offline b5rider
Blowing fuses
« on: November 22, 2013, 04:56:02 PM »
I attempted to hook up some led turn signals. The rears went well, I purchased an led-specific blinker module installed it, and the rears blinked and worked well. I then removed the front turn signals and left the bare wires sticking out .
Here is the issue:
As soon as I hook up the lights, the rearmost fuse blows. I tried to figure out which wire has power and which one is ground, but they both have power according to my meter. I hooked up the positive on the signal to one of the wires and ground the other wire coming from the bucket along with the negative from the turn signal to the frame. I heard one blink and then the fuse blew.
On the other side, my headlight blinked when I hooked up the wires the same way and then the fuse blew. Unfortunately none of the wires for the turn signals have any markings and the rat's nest inside the bucket doesn't help
1984 Honda Elite 150
1998 Yamaha 650
2004 Honda 750 ACE
1975 CB550
1978 CB400A
1978 CB550 now 603cc w/sidecar
The key to life is to make sure the line to put flowers on your grave is longer than the one to piss on it.
Re: Blowing fuses
« Reply #1 on: November 22, 2013, 08:48:09 PM »
If you have a post-1972 SOHC4 bike, the 2 wires in the front turn signal are:
one is running lamp and the other is turn lamp.
Thus, they both have power to them.
The housing is ground.
The turn wires will be either Orange or light Blue, or if the wires are Black then they will have a little collar on them in Orange or Blue near their plug-in end to the main harness in the headlight.
Offline b5rider
Re: Blowing fuses
« Reply #2 on: November 22, 2013, 09:43:02 PM »
Thank you!
well, that explains why I was blowing fuses.
I'll hook it up tomorrow (after I buy more fuses) and report back.
I saw the orange collar
Which one would be the blinker, or does it matter
1998 Yamaha 650
2004 Honda 750 ACE
1975 CB550
1978 CB400A
Black 750K8
Re: Blowing fuses
« Reply #3 on: November 23, 2013, 03:45:26 AM »
Thank you!
What bike they are not all the same?
Maybe this is why HondaMan ask this?
"If you have a post-1972 SOHC4 bike,"
Offline b5rider
Re: Blowing fuses
« Reply #4 on: November 23, 2013, 08:35:08 AM »
Its a 1975 cb550 and it has the all black wires going to the turn signals
1998 Yamaha 650
2004 Honda 750 ACE
1975 CB550
1978 CB400A
Black 750K8
Re: Blowing fuses
« Reply #5 on: November 23, 2013, 08:42:30 AM »
So you don't see the color rings on them they are short and small maybe a po cut them shorter look close. They allmost look like they are crimp on.
Black 750K8
Re: Blowing fuses
« Reply #6 on: November 23, 2013, 08:51:43 AM »
Thank you!
I saw the orange collarWhich one would be the blinker, or does it matter
I just saw this the orange collar is left turn
http://manuals.sohc4.net/CB550/CB550CWD.jpg
Offline b5rider
Re: Blowing fuses
« Reply #7 on: November 25, 2013, 08:55:00 AM »
Thanks guys.
Once I understood they were two positive wires, it was pretty easy.
In fact, too easy. I opened the bucket, traced the original wires, unplugged the original black wires going to the turn signals, and plugged in the positive wires from the new lights. I also found two empty female connections for the new ground wires by tracing the original passenger side ground wire leading from the bucket (the one welded to the nut).
Who knew the bullet connectors would be the same size after 40 years?
1998 Yamaha 650
2004 Honda 750 ACE
1975 CB550
1978 CB400A
