Author Topic: Sprocket cover rubber chain guide  (Read 690 times)
Offline Kickstart
« on: November 23, 2013, 10:40:52 PM »
I don't know what it's officially called, but it's that black hollow wedged shaped piece of rubber that's on the back side of the sprocket cover.  I call it a chain guide as the chain has clearly rubbed into mine.
Are these still available to purchase? (I don't think they're even on the parts fiche).
It looks like mine has been turned upside down at some point (as there are wear marks on both sides).  Is the one side molded to help guide the chain (mine seems to be)? I might ask my friend to try to make me one out of Teflon or something, but I want to make sure I get the original dimension correct.
Thanks,
Chris
- Chris
75' CB750F Orange flake (rider)
75' CB750F Blue (Project)
75' CB750F Painted black (Project)
No Reserve Racing #171 AHRMA
Offline Kickstart
Re: Sprocket cover rubber chain guide
« Reply #1 on: November 26, 2013, 03:43:00 PM »
bump... anyone have any info on these - suggested replacements?
Thanks,
Chris
- Chris
Offline lone*X
« Reply #2 on: November 26, 2013, 03:56:12 PM »
Something there by accident?  Something the PO tried to quite down chain rattle with?   Looks like a short section of radiator hose.   Never seen anything like that stock.
Lone*X  ( Don )
75 CB550K1
VTX1800C for two up cruisin.
Offline Kickstart
« Reply #3 on: November 26, 2013, 05:13:52 PM »
All of my 75 CB750F bikes have it...
Hmm... I have newly acquired K2, I'll take a look and see if it has one.
- Chris
Offline mitchie
« Reply #4 on: November 27, 2013, 07:40:49 AM »
All of mine have had them....  Whats wrong with that one?  worn right through?
I would try the rad hose Idea with a heat gun.
Offline Kickstart
« Reply #5 on: November 27, 2013, 02:10:58 PM »
This one isn't that bad, but the one on my other bike is worn pretty badly.
Just interested in replacement options.  Is the purpose of this part just support the chain?
I wonder if I could make a better than original part... I could make it out of Teflon... that's good for an extra 5hp, right?  :)
- Chris
Offline Johnie
« Reply #6 on: November 27, 2013, 02:24:25 PM »
The purpose is if the owner does not keep the chain adjusted it keeps it from wearing on the alumimun brace. All my 750's came with it. Never needed to replace any.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
« Reply #7 on: November 27, 2013, 02:35:09 PM »
Also helps to keep the noise down from metal on metal. Do not think they are available from Mr Honda.
Offline Kickstart
« Reply #8 on: November 27, 2013, 02:58:01 PM »
I don't think that's an aluminum "brace" where this slides over.  At least not serving a structural purpose for the sprocket cover.  There is some purpose for it being there (the aluminum and the rubber sleeve).
Intuitively, it does seem like it would have something to do with mitigating a problem with a slack chain, but what's the situation/problem Honda was providing a solution for?
Why is it important to put a chain support (or divider) there?
- Chris
« Reply #9 on: November 27, 2013, 03:20:44 PM »
IIRC, there is a part of the cover that "stands out" the cover from the cases. The screw goes through it. Without it you wouldn't get a clean cover to cover fit. The black grommet then mitigates noise from a slack chain rubbing on that standout. At one end of the wheel travel, I forget which, the problem is worse, but just for the moment the wheel is at that extreme.
Again, IIRC, it can't be used if you drop the CS sprocket a tooth,as the chain will slide on it constantly and it isn't meant for that. Just occasionally.
Working from memory. I do know they exist and I throw them away as one thing more I don't need to worry about.   ;D
