I attempted to hook up some led turn signals. The rears went well, I purchased an led-specific blinker module installed it, and the rears blinked and worked well. I then removed the front turn signals and left the bare wires sticking out .
Here is the issue:
As soon as I hook up the lights, the rearmost fuse blows. I tried to figure out which wire has power and which one is ground, but they both have power according to my meter. I hooked up the positive on the signal to one of the wires and ground the other wire coming from the bucket along with the negative from the turn signal to the frame. I heard one blink and then the fuse blew.
On the other side, my headlight blinked when I hooked up the wires the same way and then the fuse blew. Unfortunately none of the wires for the turn signals have any markings and the rat's nest inside the bucket doesn't help
