Author Topic: New PD 42b carbs  (Read 610 times)
Black 750K8
New PD 42b carbs
« on: November 25, 2013, 06:24:51 AM »
I just bought a set of carbs just to have as a spare. When I break them down for inspection and cleaning what is the best way to tell if the high speed needle set is oem or after market and if they are the correct size? Do they have any thing stamped on them?
Thanks in advance.
Offline martin99
  • UK Based, Non-
  • Adventure before Dementia
Re: New PD 42b carbs
« Reply #1 on: November 25, 2013, 04:03:23 PM »
OEM needles have numbers stamped on them, which correlate with the numbers found in the carb specs in the manual. I noticed this when I stripped my PD41s recently, so would guess it would be the same for PD42s. However, if aftermarket needles are stamped similarly, not sure how that would narrow things down for you? :-\
Build threads:
1977 CB750 F2
1958 Norton Model 99
