Author Topic: Throttle setup question  (Read 503 times)
Offline gregripko
« on: November 25, 2013, 03:26:31 PM »
When I set up my throttle I notice that my wrist twists all the way back and it's no where near the end of the throttle travel (the point in which the throttle stops).... Is there anything I can do about this or is this normal
Offline martin99
  • UK Based, Non-
  • Adventure before Dementia
Re: Throttle setup question
« Reply #1 on: November 25, 2013, 03:54:57 PM »
I think it's normal. I have the same problem. I find using fatter grips helps, although in theory it means you have to turn further for the same result it is definitely easier on the wrists.
Build threads:
1977 CB750 F2
1958 Norton Model 99
Offline gregripko
« Reply #2 on: November 25, 2013, 04:34:12 PM »
Hmm yeah it sorta sucks because the real power on the cb550 doesn't really show up unless it's in the upper range of rpm which for my case is a majority of my wrist twist
