Author Topic: Another Craigs List find!  (Read 4306 times)
Offline 195suz
« on: December 01, 2013, 10:40:44 AM »
I was searching Craigs list like I do everyday and ran across an add for a couple of cb750 motors, always the sucker for a SOHC I started to study his two pics and the first thing I noticed that the one cylinder wasn't stock and the bore was quite large the second thing I saw is what appeared to be an H beam rod sticking out of the motor (no pistons). It was about an hour drive for me so I called my buddy that was much closer, he went and looked at them and called me and in his code tells me you need to pay this guy and not waste his time, That means buy these now. Well this is what I found for 325.00
Offline 195suz
Re: Another Craigs List find!
« Reply #1 on: December 01, 2013, 10:42:33 AM »
Heres a couple more
Offline 195suz
« Reply #2 on: December 01, 2013, 10:44:07 AM »
and a couple more
Offline 195suz
« Reply #3 on: December 01, 2013, 10:45:30 AM »
and the last one
Offline 195suz
« Reply #4 on: December 01, 2013, 11:02:31 AM »
So what I have found so far, 73mm RC Engineering cylinders, ported and polished head with oversized valves, a very large cam marked made in the USA I have not verified the lift on it, Carillo H beam rods, Spocket support plate, A very early dyna ignition, The head and cylinder have been o-ringed (metal)
« Reply #5 on: December 01, 2013, 11:06:52 AM »
That would make such a nice wrapper for my stroker crank.
Offline Greggo
  • Somebody's
  • Helmets Save Lives. Period.
« Reply #6 on: December 01, 2013, 11:49:59 AM »
You did REALLY WELL ;)
« Reply #7 on: December 01, 2013, 11:55:24 AM »
Santa is early this year! :)
Offline Greggo
  • Somebody's
« Reply #8 on: December 01, 2013, 12:05:52 PM »
I wonder what/if anything has been done to the crank..
Offline 195suz
« Reply #9 on: December 01, 2013, 12:11:33 PM »
The second motor is a big bore as well with H beam rods but only 3 of them.
« Reply #10 on: December 01, 2013, 12:55:54 PM »
Do you still have the yellow frame?  Would look good in there..
Offline 195suz
« Reply #11 on: December 01, 2013, 01:25:21 PM »
Yup, still have the yellow frame. Was starting to build a stroker but now that I found this, I'm probable going with this motor as long as everything is ok inside when I tear it down.
 Took the head apart intake valves are shot but the rest not to bad. Need to figure out what cam is in it.
Offline BPellerine
« Reply #12 on: December 01, 2013, 05:16:35 PM »
wow! :)
1978 CB 750K ard and webers
another anfob
Offline 01Thomas
« Reply #13 on: December 02, 2013, 12:07:12 PM »
You owe your buddy who went to look at it for you a bottle of brandy!
Online Don R
« Reply #14 on: December 02, 2013, 09:12:02 PM »
Possibly the sprocket support could be duplicated by a talented machinist in the us (or canada) so others could take advantage and you could have a new one or two for yourself.
 And sweet find, congrats.
Offline jaguar
« Reply #15 on: December 04, 2013, 02:04:27 PM »
Nice score.
Jealous
Offline 195suz
« Reply #16 on: December 05, 2013, 03:06:32 PM »
Don, I will take some better pics of it so you can see it it's kind of cheesy the way it mounts and to me doesn't seem to really offer too much support.
Offline windwalker
« Reply #17 on: December 05, 2013, 11:26:30 PM »
Hey Lewis listen to 01thomas as i do drink brandy.
Offline 195suz
« Reply #18 on: December 08, 2013, 11:40:37 AM »
Well I finally got time to take the bottom end apart and found this thing has a 3mm stroker crank  :) Don here are some more pics of the bearing support. I didn't notice it before but it looks like it gets bolted to the upper and lower rear motor mounts.
Offline 195suz
« Reply #19 on: December 08, 2013, 11:45:33 AM »
And a couple more of the sprocket
Offline dragracer
  • CB750F Dragbike
« Reply #20 on: December 08, 2013, 12:45:35 PM »
I think if Don does get the support plate from you, he might be willing to share the details of the plate with all of us here on the SOHC forums. I know Bill Benton will need one when he builds the wheelie bar bike and i may be at that point myself with the offset sprocket i put on my no bar bike. The SOHC output shaft is small and may not withstand a lot of hard launches over time- especially with a 7" slick. Would also like to see more pictures of the outboard sprocket and the inside of the plate when you completely disassemble every thing. Can i assume the bearing is inside the nose of the sprocket and rides on a nipple thats bolted to the plate??
Thanks a lot of sharing the pictures of your find. We should all be so lucky.
Good luck with your new motor project. Looking forward to seeing how it progresses.
« Last Edit: December 08, 2013, 12:51:51 PM by dragracer »
