Author Topic: I broke my nipple. Help  (Read 1620 times)
Offline fdbrat
« on: December 01, 2013, 11:21:54 PM »
Culprit - 75 cb750F
I tried my best to loosen the bleeder nipple on the rear disc brake. Well it snapped off. I broke my nipple.
Should I try and fix it? If so how?
Also upon inspection my Master Cylinder is thrashed beyond belief. I declare it unfit to rebuild. To much metal damage. Where o where can I find a replacement that isn't an arm and a leg?
The bike is almost bake on the road.
1975 CB750F
4-4, Dyna S and box
5 ohm coils / 5k ohm caps
In- .05 / Ex- .08
San Luis Obispo
Offline martin99
  • UK Based, Non-
  • Adventure before Dementia
Re: I broke my nipple. Help
« Reply #1 on: December 02, 2013, 01:22:52 AM »
You'll need to remove the caliper, put it in a vice and drill out the remaining part of the nipple, then re-tap. From memory, a 5.5mm drill should do it followed by a 6mm tap. Don't be tempted to use easy-outs, if one of those snaps off in there it will be a bear to remove.
Build threads:
1977 CB750 F2
1958 Norton Model 99
Offline fdbrat
« Reply #2 on: December 02, 2013, 02:12:25 AM »
Sounds like a plan. Thanx Oldskool.
I think I'm just going to mod a newer style M/C to fit the bike. Ill report back.
1975 CB750F
4-4, Dyna S and box
In- .05 / Ex- .08
San Luis Obispo
« Reply #3 on: December 02, 2013, 09:53:25 AM »
Ec a left hand drill if you are drilling it out..
Black 750K8
« Reply #4 on: December 02, 2013, 10:56:07 AM »
Don't you worry about the seat?
Offline bjbuchanan
« Reply #5 on: December 02, 2013, 11:34:49 AM »
Doesn't speed bleeder R&R these things for like 15$ shipped?
« Reply #6 on: December 02, 2013, 01:56:35 PM »
Yes they do. Smart move, easy and you won't damage anything. Can't say about the price but it IS reasonable AND you'll get a Speed Bleeder too. Ask for stainless and get one for your front too as a present to yourself and a thank you to Speed Bleeder.
Good luck on the rear master. That may take some time to source a good used one. New has not been available for MANY moons. Also the kit is not available from Honda I'm thinking. You can use a 75-79 Goldwing kit though. Slightly longer piston bolt.
Black 750K8
« Reply #7 on: December 02, 2013, 02:01:52 PM »
bjbuchanan  Yes 100% and for some well worth it if time is not an issue. But back to what I brought up is there a seat at the bottom that the bleeder has to match up with ? If you drill into it will it mess it up? Just asking not sure but the OP should know before drilling.
Black 750K8
« Reply #8 on: December 02, 2013, 02:03:53 PM »
 Jerry Rxman Griffin aka MuthaF'eris to fast ;)
Black 750K8
« Reply #9 on: December 02, 2013, 02:05:41 PM »
Jerry I know what you were thinking when you first read the title ;D
Offline fdbrat
« Reply #10 on: December 02, 2013, 02:07:37 PM »
I do like to try and do things my self... But the logic of having a pro handle it sounds like a safe bet.
Thanx fellas. Two Nipples are better than one. The nip broke flush. So I'm not completely sure what you mean by seat. Ill be having it fixed professionally.
I also discovered a 71 Fiat has a brake hose with a Banjo and a female M10x1.25 fitting. Which you can pick up at the local auto store. That 1.25 is hard to find for cars.
Problem is its only a foot long. Just a foot note.
And again thank you for the help. And yeah I figure a tittle has to be funny.
1975 CB750F
4-4, Dyna S and box
In- .05 / Ex- .08
San Luis Obispo
« Reply #11 on: December 02, 2013, 02:14:28 PM »
tittle - title, whatever  :D You guys are perverts  ;)
Bent it hell, I broke it... There's a joke in there somewhere  ;)
Check in with Bill Benton on spares. I think I saw some in v2.0 Bat Cave recently.
Black 750K8
« Reply #12 on: December 02, 2013, 02:39:20 PM »
What I am talking about is something like your carb jets needle & seat. I think if you look at the end of a new one it will have a taper that has to match up. So I was trying to tell you if you take a drill to it you don't want to mess up the seat once you get the broken part out. But sending it off is best I'm glad Jerry brought it up I had forgotten all about them doing that service. I do have the speed bleeder and like them.
Offline martin99
  • UK Based, Non-
« Reply #13 on: December 02, 2013, 03:23:45 PM »
I've drilled these successfully before. The trick is to go careful - if you have a spare bleed nipple it helps to estimate the depth to drill. You don't need to drill down to the seat, use the correct size drill and it works out the same size or slightly larger than the widest part of the taper on the nipple (just below the threaded section). The drill will cut the taper off before it bottoms on the seat. Once you get to that you can tip the caliper upside down and shake the remaining taper out of that hole you just drilled, leaving the seat intact.
Build threads:
1977 CB750 F2
Offline fdbrat
« Reply #14 on: December 02, 2013, 04:03:14 PM »
My bike is a Super Sport. This is all in regards to the rear M/C and rear caliper.
1975 CB750F
4-4, Dyna S and box
In- .05 / Ex- .08
San Luis Obispo
« Reply #15 on: December 02, 2013, 04:07:45 PM »
Oh....rear masters are hard to come by.
Offline fdbrat
« Reply #16 on: December 02, 2013, 04:53:37 PM »
Haha yup.
Ok here is some eye candy.
1975 CB750F
4-4, Dyna S and box
In- .05 / Ex- .08
San Luis Obispo
Offline CBcafeJunkie
  • 75 CB750F
« Reply #17 on: December 03, 2013, 04:14:15 AM »
I screwed my rear caliper up also so bad I'll need to have the hole soldered and re tapped or I found some brass inserts that have a bleeder in them. Unfortunately I thought I could do it myself and the hole is just slightly to big so I'm looking at having it soldered in. Wish I had gone professional to start with :(
