SOHC/4 Owners Club Forums
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
SOHC/4 Shop
Home
Help
Login
Register
Donate
Tech Forums
SOHC/4 Bikes
Topic:
Can I remove this?
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Can I remove this? (Read 1143 times)
RodPlunger
Annoying New Guy...
Full Member
The road goes on forever....
Can I remove this?
on:
December 02, 2013, 12:06:11 PM »
Hi all,
Quick question about removing the cover on the side of the cylinder. I looked at the parts diagram and it shows 2 O-rings behind it. Is this cover holding oil back? Can I just pull it off to polish it without opening up a can of worms? Thanks
Logged
1977 CB550F Supersport
"We want to be free.
We want to be free to do what we want to do.
We want to be free to ride.
We want to be free to ride our machines without being hassled by The Man...
And we want to get loaded!
dave500
Really Old Timer ...
WHAT?no gravy?
Re: Can I remove this?
Reply #1 on:
December 02, 2013, 12:11:12 PM »
yep you can remove it for polishing,youll get a few drips thats all so long as the engine isnt running.
Logged
Toxic
Expert
Reply #2 on:
December 02, 2013, 12:33:48 PM »
and since you are relatively new here,,,, in case you haven't noticed dave500 is pretty much one of THE local gurus of all things related to 500's
Logged
RodPlunger
Annoying New Guy...
Full Member
Reply #3 on:
December 02, 2013, 12:42:50 PM »
Yes, I am relatively new. So, thank you all for your patience and advice, and I will put Dave500 on speed dial.
Logged
Black 750K8
Guest
Reply #4 on:
December 02, 2013, 12:51:20 PM »
Dave for the 500. TT for all things 550. HondaMan well he is the man all things Honda. Me I'm nobody
. Wellcome to the madness lots of good folks here.
Logged
kammery
Full Member
Reply #5 on:
December 02, 2013, 05:00:14 PM »
Yes you can . I remove mine on my 550 .The screws where really tight and slightly corroded . Use a high quality impact bit and a heavy hammer . If you have a micro torch heat them up and then try to loosen them .
Logged
RodPlunger
Annoying New Guy...
Full Member
Reply #6 on:
December 02, 2013, 09:51:35 PM »
Have you ever tried using a hammer drill? I don't currently have an impact driver. And/or do you have one that you recommend? Thanks
Logged
kammery
Full Member
Reply #7 on:
December 03, 2013, 04:04:16 AM »
Never tried a hammer drill .I do own one . Go to Sears , get the highest quality bits they have there are three sizes . Stay away from harbor freight bits . I have had Craftsman bits for years . If one breaks you can exchange them . The bits I have are black ones in a chrome body P-2 and P-3 are the part numbers.
Logged
dave500
WHAT?no gravy?
Reply #8 on:
December 03, 2013, 09:58:54 PM »
be carefull impacting the retaining screw,youll bend the bracket behind it,those brackets are left and right hand aswell.
Logged
RodPlunger
Annoying New Guy...
Full Member
Reply #9 on:
December 03, 2013, 10:04:22 PM »
What do you mean left and right? As in side specific, or reverse threaded?
Thanks for the tip on the impact driver...
Logged
dave500
WHAT?no gravy?
Reply #10 on:
December 03, 2013, 10:07:11 PM »
side specific,they are marked L and R.
Logged
fdbrat
Hot Shot
Reply #11 on:
December 03, 2013, 11:01:39 PM »
Every time someone removes those covers... A kitten dies...
It's your choice if you want to be a Kitten killer.
Logged
1975 CB750F
4-4, Dyna S and box
5 ohm coils / 5k ohm caps
In- .05 / Ex- .08
San Luis Obispo
Powderman
Master
Reply #12 on:
December 03, 2013, 11:07:03 PM »
Use JIS bits or you will most likely strip them using Phillips bits.
Logged
Print
Pages: [
1
Go Up
« previous
next »
Tech Forums
SOHC/4 Bikes
Topic:
Can I remove this?
