Author Topic: Noob-O-Rama  (Read 703 times)
Offline burmashave
  • Forum Immoderator
    • burmashave.net
Noob-O-Rama
« on: September 01, 2006, 03:48:46 PM »
Hi! I really should introduce myself; I've been lurking here long enough to feel as if I know some of you  :)
First: THANKS for the many clear and knowledgeable posts!  The archives have carried me far along, and the posters here are the friendliest and most helpful I've encountered.
I picked up a 1977 CB750K a few years back; however, I didn't do anything with it (other than buying parts) until I got the bug last spring.  This summer, I've been working like a maniac on it in the hope that I might get some riding in before cold weather.
My bike in pretty good condition.  I've replaced/rebuilt much of the electro/mechanical items: clutch, brake master and slave cylinders ("dgs38" on ebay sells excellently machined slave pistons), frt/rear pads, regulator/rectifier, ignition & coils (Dyna 2000 & 2.2 ohm coils), new control cables, new 4-4 pipes from David Silver, newly chromed covers, cool (pirate) clock overlays from Carpy, and Keihin CR 29 carbs.
Compression is uneven.  I plan to do a top and bottom end this winter.
I've got only two remaining issues (I hope) before I can do serious riding.  The charging/battery system is faulty, and my carbs seem too rich (dry black carbon fouled plugs).  I'm working through the charging system guide from Mike Nixon's Motorcycle Project, and then I will tackle the carbs which will need jetting changes to lean them out.
Thanks again for all the hard work that goes into this site!
Quote from: SOHC Digger, RIP
'77 CB750k
Offline clarkjh
  • Expert? If only.
  • Surely and Samson are now Co-habitating
Re: Noob-O-Rama
« Reply #1 on: September 01, 2006, 04:02:20 PM »
Welcome.
Pics? <when the gallery is back up>
James
SOHC/4 #3328
SOHC/4 Gallery: http://www.sohc4.us/gallery/v/members/personal/clarkjh/
1974 CB550, 40000 Miles
1980 GL1100, 102789 KM - Back on the road after a complete engine rebuild.
*** Why, oh why, is it always head gaskets with me?***
Offline Bob Wessner
  • "Carbs Suck!"
Re: Noob-O-Rama
« Reply #2 on: September 01, 2006, 04:16:10 PM »
Welcome. Sounds like you have a good metholodgy going and are making good progress. Good luck and keep us posted.
P.S. Hope you get that ride in.
