Author Topic: Oil Drain Bolt 15331-323-003  (Read 543 times)
Offline zeech
« on: December 04, 2013, 04:12:45 PM »
Can't seem to track these down anywhere... Any ideas? Also, a similar bolt to this one one on the bottom of case near the alternator is stripped out 15332-300-000. Any ideas?
« Last Edit: December 04, 2013, 04:17:22 PM by zeech »
Re: Oil Drain Bolt 15331-323-003
« Reply #1 on: December 04, 2013, 04:34:51 PM »
"oil galley cap"
a few on ebay available.
someone with old cases might be able to pull a few for you.
also here...http://www.cycle-parts.com/Products/452835-15332-300-000.aspx
Offline Bodi
« Reply #2 on: December 04, 2013, 05:17:36 PM »
The red circled part is on the oil pump pressure relief valve, I wasn't aware that the 550 used the same part here as the opposite side crankcase oil gallery plug. These are fairly common on ebay etc. as they were used on quite a list of models and years, if you search for the part number on partzilla you'll see some of them. Often the plug on the oil gallery is drilled and tapped for an oil pressure gauge.
