Author Topic: Show me your center stand stopper (4 into 1 exhaust peoples) :)  (Read 11003 times)
Offline SKTP
« on: December 06, 2013, 10:24:52 AM »
http://forums.sohc4.net/index.php?topic=115536.0
Yes I have searched and found a few threads on this, but I figure there have to be more people who have done this
I gave my center stand away (not smart) originally thinking I would get a Yoshi-style pipe
But now I have the triple-A and I miss the ease the stand provides for all aspect of working on the machine ie: wheel removal
I just bout a new one on ebay (sadly without the pin. Waiting for that) In the meantime...please show me your stoppers
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
Re: Show me your center stand stopper (4 into 1 exhaust peoples) :)
« Reply #1 on: December 06, 2013, 10:29:55 AM »
Mine is nothing more than flat bar, bent in 90 degrees and tightened under the passenger peg, will take a picture when I get home.
« Reply #2 on: December 06, 2013, 10:36:04 AM »
mine ran me about $5 for the bar and rubber stopper, all from Home Depot
...and some leftover black paint.
Offline brooze72
« Reply #3 on: December 06, 2013, 10:41:49 AM »
Here is mine, chromed, came with the 70's 4/1 aftermarket Japanese exhaust
1972 CB500K1 - restored rider
1981 CB650C - new project
Offline SKTP
« Reply #4 on: December 06, 2013, 10:52:22 AM »
You don't have any issues with it twisting (front to back with the single mounting-point)?
Anybody put it on the exhaust side to "hide" it better behind the pipe?
Again I am waiting for the pin...There must be a way to build it into the exhaust-hanger bracket?
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
« Reply #5 on: December 06, 2013, 10:56:01 AM »
never twisted on me.  hits flush to the stopper.
there are quite a few threads already, with pictures of the hidden one mounted under the frame on on the center stand.
search center stand stop
« Last Edit: December 06, 2013, 10:58:12 AM by flybox1 »
Offline SKTP
« Reply #6 on: December 06, 2013, 10:59:27 AM »
Thanks  :D
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
Offline andrewk
  • doin' it.
« Reply #7 on: December 06, 2013, 02:08:14 PM »
My Triple A has the shorter megaphone, so this might not work for you, but I used an extra long bolt in the muffler support mount, and catches the end of the center stand.  The load isn't on the megaphone, since it's bolted to the frame there too.  I'll snap a pic and post back.
Regarding the other forms of stop, the idea that I've always seen (and what was originally employed on my F2) is a stop bolted to one of the swingarm pivot pinch clamps.  The stop is a wide flat tab that hits the top part of the centerstand, bent to adjust the height of the centerstand.  This is an easy solution, but make sure to use a substantial piece of metal for the task.  Whoever made the one for my F2 used steel strapping, and it deflected over time.  A friend's F1 has a nice tab made out of 1/4 inch steel.
And, not to over think such a simple modification, but the other key to getting the tab method to work well is to get sufficient torque on that pivot pinch clamp.  I add a spacer in between the clamp ends to limit deflection, which seems to work well.  (I think I used/modified an ignition coil spacer/standoff)  Just make the spacer short enough so that the "clamp" still squeezes down on the pivot pin.  If you just bolt the tab to the clamp, the tab will move around, requiring occasional (and frustrating) adjustments.  No good in my book.
Offline rb550four
« Reply #8 on: December 06, 2013, 02:54:03 PM »
I ran into the same issue with the centerstand hitting the chain, asked the forum , came up with  ideas like what you have here or remove centerstand.... didn't want to do that.  So I ended up removing the two bolts on the center stand pivot rod, put in longer bolts and fenderwashers on the top, so when the stand is up it is stopped by the fenderwashers. An okay idea but will improve it this spring with an off set bar mounted bolt to bolt, again over the stand, might add some rubber bumpers ,not sure yet. I also trimmed back where you put your foot when engaging it, there's no pipes on that side with headers so it doesn't need to stick out so far.
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« Reply #9 on: December 10, 2013, 11:22:48 AM »
My stopper is on the exhaust side currently, but I might switch it to the other side...
--Evan
1975 CB750K "Rhonda"
Offline CoachDoc
  • 1974 CB550, 2005 GL1800, 1997 Valkyrie Standard
« Reply #10 on: December 11, 2013, 04:57:41 PM »
I'm back to stock 4-4 exhaust, but during the time I ran a 4 into 1 exhaust I left the center stand off. Whenever I wanted to work on the bike, I used a crowbar end cut the correct length to slip into the center stand in place of the regular pivot
axle, which is a tight fit. I would just hold the center stand in the right position, insert my faux axle and lift the bike on the center stand in the usual way. Had the advantage of a cleaner look, lighter weight, and center stand on demand so to speak.
« Reply #11 on: December 11, 2013, 05:00:44 PM »
A piece of 3/4 OD tubing works well for the center stand pivot. I put washers and cotter pins on both ends.
Offline thelowmax
« Reply #12 on: October 05, 2014, 09:47:14 AM »
I always get a chuckle when I point out my stand stopper.
What am I doing and why am I doing it? Those are excellent questions.
'72 Amen Savior/'77 CB750K Chrome/Da Bhudda(project)
'73 CB750K Green/El Verde (beat)
'76 CB750K Red/The Cinnabomb (sweet)
'77 CB750K Black (frame and parts) CANNIBALIZED
'77 CB750K Dark Purpley/Scooty Puff, Jr. (la beast)
'78 CB750K Black (struggling) SOLD
'78 CB750K Blue Flake/CiocioSan (minty)
'81 CB750C Poiple/Barbie'sDreamMotorcycle SOLD (darnit!)
'89 Trek 21" 21 speed Green/YaBiatch (the wife)
Converse One Stars size 8.5 Black/Sneaks (suede)
Offline dusterdude
« Reply #13 on: October 05, 2014, 02:32:05 PM »
Dont have a pic handy but i use a piece of angle steel and run a bolt thru the passenger peg hole,does a good job
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline eideteker
« Reply #14 on: October 05, 2014, 07:46:51 PM »
Since I put the 550F 4-1 header on my 500 my center stand resides in the garage, I slide it back in if I'm doing an oil change or anything else that requires the rear wheel to be off the floor.
"Spit on the tip of your finger, lube the inside of the hole, and then wiggle it around and twist a bit back and forth as you apply pressure." - mystic_1
1973 CB500K - not bad for a first bike
2009 SFV650 - torquey, reliable 90° V-twin
« Reply #15 on: October 06, 2014, 06:49:47 PM »
 My stoppers look like the ones shown, I found a centerstand that was narrowed and it fit my bike with the 4-2 hooker header. I shimmed it to the right side and it fits up tight to the muffler.
Offline s7paul
« Reply #16 on: October 06, 2014, 07:01:29 PM »
When I had a 4-2 on my 500 I just used a small piece of flat steel bar, fixed to the stand pivot using a slightly longer pinch bolt (on the right side as you sit on the bike). Worked a treat, and so inconspicuous that I haven't even bothered to remove it, now that I have the OEM 4-4 fitted.
Offline enwri
  • So that noise is normal?
« Reply #17 on: October 07, 2014, 06:51:17 AM »
This has worked well.
« Last Edit: October 07, 2014, 06:57:16 AM by enwri »
77 CB 750 k.. 29 years and counting.
91 TDM 850 (No.34) so comfy and soft
8? XJ 550 meh...
76 XL 350 Super Sport stump puller..
80 XR 200 idiot proof
75 MX 250 b dangerous
« Reply #18 on: October 07, 2014, 07:16:50 AM »
Offline Really?
The Wife's Bike - 750K5
The Kid's Bike - 750K3
Offline Really?
« Reply #20 on: October 07, 2014, 10:07:37 AM »
cb750supply.com has one.  I has this or something very similar that came with my Mac 4-1.
Offline Jonm99
« Reply #21 on: September 29, 2017, 05:42:52 AM »
Here's mine, a little black paint on the washer and good to go!
1977 cb750k with original airbox, PD41a carbs, slow jets=35, main jets=120, Delkevic 4in1 headers, 18" Cone engineering QC muffler, 7" headlight, dynatek ignition, ss r/r, clip ons, and ebc front brake rotor. All the rest stock, for now. First restoration, lots to learn!
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
« Reply #22 on: September 29, 2017, 08:09:44 AM »
Oh yea?
« Reply #23 on: September 29, 2017, 08:18:07 AM »
Oh yea?
The guard off some magical Final Fantasy sword  ;D
  • Holy Cow! I'm a
« Reply #24 on: September 29, 2017, 08:26:29 AM »
Oh yea?
That is actually the blade (some of it).   Have the pommel for that sword somewhere 🙄
