Author Topic: Weeping head  (Read 890 times)
Offline SohcCBs
  • 76 CB836F 77 GL1000
Weeping head
« on: September 02, 2006, 08:00:04 AM »
Sometimes you miss something and find it later and say, "YEA", or "How dumb was that!"  I'd always figured that my head gasket was weeping because of where I was finding the oil dribbling thru the head fins.  I knew also that the tach cable was leaking.  After spending an initial $2000 on this bike and having a mostly ruined back, I just wasn't up to the task of trying to pull a 170 Lb. Engine.  The bike has always run like a banchi and my research showed that weeping from the oil return "O-rings" would'nt cause anything but a messy bike.  I'd also heard from many that the tach cable seal was no longer sold or manufactured.  That was wrong.  My local Honda dealer carries it….even if made for the Dohc CB750, it's listed for mine.  There are other on-line sourses for it too.
Anyway, after finally replacing the tach cable seal, I've discovered that my head gasket is NOT weeping, so YEA!, or How dumb is that?  Now I'm spending some time cleaning the bike, and I guess I'll have to paint it, too, considering I've put nearly 30k miles on it this way.
Oil from inbetween the fins can just be the tach cable seal.
« Last Edit: September 02, 2006, 08:03:07 AM by SohcCBs »
Offline Steve F
Re: Weeping head
« Reply #1 on: September 02, 2006, 08:31:23 AM »
Or it can be those pesky little rubber plugs under the cam holders.  Over time they get hard and no longer do their job.  You have to pull the rockers, cam and cam bases (holders) to get at them.  They're part of most gasket sets, and require just a slight coating of silicone sealant where they meet the head to totally ensure a leak free repair.
Offline SohcCBs
Re: Weeping head
« Reply #2 on: September 02, 2006, 08:53:28 AM »
Yes!  Fortunately neither is leaking.  It was just the tach cable.  I could kick myself in the a**.
Offline Tim.
  • www.DOTHETON.com
    • DO THE TON
Re: Weeping head
« Reply #3 on: September 02, 2006, 09:10:02 AM »
Yep - the tach seal has fooled many of us I think.  In fact, when I bought my bike there wasn't one at all - I didn't know there was supposed to even be one there!
