Author Topic: Removing lowers from tubes???  (Read 809 times)
Offline fdbrat
« on: December 10, 2013, 02:26:25 PM »
I've read post about sticking a broom stick to add tention. Still un able to remove that little booger of a bolt from the plunger. I do not have acess to air tools...
What next?
1975 CB750F
4-4, Dyna S and box
5 ohm coils / 5k ohm caps
In- .05 / Ex- .08
San Luis Obispo
Re: Removing lowers from tubes???
« Reply #1 on: December 10, 2013, 02:40:09 PM »
gain access to air tools
sorry ;D
Offline calj737
  • I refuse...
« Reply #2 on: December 10, 2013, 07:33:43 PM »
Heat. More heat. Lots more heat. And put it directly on the bolt until it glows cherry red.
Offline MoMo
  • Ride like you're invisible
« Reply #3 on: December 10, 2013, 07:36:57 PM »
sorry ;D
sorry ;D
Ditto,  maybe take it to a local shop or garage to have them spin it off. Or buy an 18v impact wrench...Larry
Offline Blackhole
« Reply #4 on: December 10, 2013, 08:06:33 PM »
If you put a taper on the end of the broom stick with a belt sander it will work better.  Give the broom stick a couple of taps with a hammer to seat it then put the stick in a vice so you have both hands free.
Offline fdbrat
« Reply #5 on: December 10, 2013, 08:43:42 PM »
I got it off earlier. I used a file with a tapper and gave it a thump. Worked like a charm.
Thanx a gain fellas. Now it's lowered properly.
1975 CB750F
4-4, Dyna S and box
In- .05 / Ex- .08
San Luis Obispo
