Author Topic: Concerns about rusted frame  (Read 13093 times)
Offline Kickstart
« on: December 10, 2013, 04:09:37 PM »
Attached are pictures from my 72 CB750.
I noticed the other day (while taking a brake from my other rebuild) there seems to be some significant rust on the frame around where the swingarm mounts.
The left side seems to have a little hole in the steel, and the right side has paint flaking off the welds.
Is this safe/normal, and if not is this repairable?
I was thinking about building this bike into an AHRMA race bike - not so sure now after seeing this.
Thoughts?
Thanks,
Chris
- Chris
75' CB750F Orange flake (rider)
75' CB750F Blue (Project)
75' CB750F Painted black (Project)
No Reserve Racing #171 AHRMA
Offline LesterPiglet
  • 1977 CB550F2
Re: Concerns about rusted frame
« Reply #1 on: December 10, 2013, 04:17:06 PM »
That doesn't look significant to me. Tap the rusty parts with a fine chisel or somethingto remove the scale and see how bad it is.
Oh! Is that a hole? I would weld that up.
It looks ok.
« Last Edit: December 10, 2013, 04:18:37 PM by LesterPiglet »
Offline MoMo
  • Ride like you're invisible
« Reply #2 on: December 10, 2013, 05:54:46 PM »
Must be the area where you live ::), my 750 red rider was way worse than that and came from your area.  I would bet the inside of the frame is filled with rusted metal flakes.  As mentioned to a lot of tap testing, any hollow sound should be an alarm.  BTW,  I had to replace the frame on mine...Larry
« Reply #3 on: December 10, 2013, 09:43:12 PM »
Those holes are the upper "breather" holes for the lower frame. The other "end" of those holes should be down by the bottom front engine bolsters, on the bottom of the frame. They often get clogged up with rust flakes.
Like Momo said, "tap testing" is a good way to check for thin spots, or put some rubber in the jaws of slip-joint pliers and firmly (not HARD) squeeze the frame along the runs to see if it crushes. The worst spots on the 750 frame are at the bottom of those engine bolsters, if they were painted or crudded shut. The frames are easy to fix, I've done several myself.
On the 1970-71 K1, many of the lower holes were forgotten in production (even some K2 bikes were this way, before it was over). There was a "quiet" service memo sent out to have dealers watch to see if the holes were missing at the lower bolsters, and the instructions were to drill a 7/32" (3mm) hole behind each one, if not present. More than one of the ones I did had water come out during this 'mod'. I usually took an oil squirt can and squirted a bunch of oil into the holes you show, until it oozed out the [new] bottom ones, hoping to extend the frame life. Now, when I have frames out of bikes, I spray CRC into the holes until it RUNS out of the lower ones, then turn the frame over and do it the other way. That will stop any rust, almost forever, right where it is.
Offline MoMo
« Reply #4 on: December 11, 2013, 03:47:01 AM »
The result of long term neglect
Offline Toxic
« Reply #5 on: December 11, 2013, 04:59:48 AM »
I think all of the methods mentioned above are proven and valid ways to determine and repair or minimize rust would you trust it on a race bike?  I wouldn't.  The rust may not be localized to the areas you see.  There could be other areas that are weakened.  For what it would cost to pick up a frame in better shape, it would be worth it for peace of mind.
If it's to be a race bike does it matter if the frame doesn't match?
If it were a daily driver, I wouldn't have a problem with a proper repair and inspection of the rest of the frame.
Gary
« Reply #6 on: December 11, 2013, 07:49:01 AM »
I'd proceed with the race prep. If you find anything scary look for another frame. If that's out of your price range maybe a race bike isn't the best idea. They are always more $$$ than we expect.
Offline edwardmorris
  • Youngish
« Reply #7 on: December 11, 2013, 01:31:31 PM »
WHYYY did I see this? So terrified now, gotta go check my frame inch by inch, given the history of how many PO screw ups its had so far. I was planning on using Eastwood's internal frame spray on mine wherever possible to stop rusting. Seems to have worked well for people restoring cars.
Link
http://www.eastwood.com/internal-frame-coating-w-spray-nozzle-qt.html
« Last Edit: December 11, 2013, 01:33:30 PM by edwardmorris »
Offline MoMo
« Reply #8 on: December 11, 2013, 02:46:03 PM »
Sorry to scare you but left untended that could be the result.  Funny thing about that bike is the rest of the bike was rust-free...Larry
« Reply #9 on: December 11, 2013, 04:28:22 PM »
Was that one a K1? It resembles some others I saw that didn't have "the hole" drilled.
Offline lucky
« Reply #10 on: December 11, 2013, 04:35:37 PM »
It looks ok.
You cannot weld rust.
The frame is only 1/16 inch thick.
  • Youngish
« Reply #11 on: December 11, 2013, 06:59:43 PM »
Oh thank goodness, looks like my frame is alright. I will update my build thread and pix there and stop hijacking this one. !!PAGING HONDAMAN!! mine's a super early K2, mind showing me where I can drill a hole from the "quiet" memo? I sprayed CRC in the holes I found and it didn't run anywhere, came out the same hole when I flipped the frame. My build thread in my sig.
Offline Kickstart
« Reply #12 on: December 11, 2013, 07:47:04 PM »
No worries about the thread hijack edwardmorris.
I believe the holes should be drilled here (see attached - this is a picture of my F0 frame - without holes.)
I believe it's a couple of inches before the front mounts (or behind?)
- Chris
Offline Kickstart
« Reply #13 on: December 11, 2013, 07:53:01 PM »
Well... Argh!
I guess I paid too much for it.  It's a K2, so it should have the drain holes.
Anyone know a good frame repair shop near the Philadelphia area?
- Chris
Offline MoMo
« Reply #14 on: December 11, 2013, 07:53:36 PM »
No,  a 75.   I found a frame that had the same serial numbers except for two digits.  I changed the digits :-X
Bike with new frame
  • Youngish
« Reply #15 on: December 11, 2013, 08:32:19 PM »
Interesting. So the holes in the pix from your first post, you spray CRC there and its supposed to come out through these? Pardon the noobness, trying to make sure I stop rust in its tracks.
Offline Kickstart
« Reply #16 on: December 11, 2013, 08:47:47 PM »
Hmm... I'm not sure exactly what spot Mark (Hondaman) is referring to as the Upper vent holes.
Does your bike have the lower holes?
- Chris
  • Youngish
« Reply #17 on: December 11, 2013, 08:57:37 PM »
Don't think so, some pix here
http://forums.sohc4.net/index.php?topic=126735.75
« Reply #18 on: December 11, 2013, 09:35:30 PM »
You can make them anywhere in that area, at the lowest point. Honda's old recommendation was just behind those bolsters. The general idea is: if moisture gets in there, it must have 2 holes for some flow-thru to help dry it out. The engine heat also helps.
  • Youngish
« Reply #19 on: December 11, 2013, 09:41:34 PM »
So, if my frame tubes have no holes on the top side by the steering stem, then the tubes are sealed and I don't need the new holes? Or are there for sure holes in the steering stem area that I can't quite see?
« Reply #20 on: December 11, 2013, 09:54:39 PM »
There are usually holes near the web that is shown above as the rusty spot. On mine, for example (not visible to a camera, now that I just repainted it) there are holes in the frame tubes where they go up from the web plates, where the rear tubes are joined to the rear downtubes. The rear (footpeg/pipe mount) tubes meet the rear downtubes and the holes that were probably cut into those downtubes to receive the rear tubes are bigger than those tubes, so there are unfilled openings ('holes') above them, near the little holes in the sideplates (gusset plates). I admit to not looking at every frame I see here, but those I can think of where I have oiled them up with CRC had the holes to spray in at this junction.
This raises a good question for some of the really rusty frames I've seen, though: I wonder if some of these holes were not so big where the rear tubes meet the main "loop", and this caused a non-vented situation altogether, or even more: if these holes got welded shut in the process, before the gusset plates were added, and no further work was done? The early frames often were not treated with quite the respect of the later ones, particularly the beefier New Factory frames.
The frames on the Old Factory bikes, in particular, were subject to these sorts of vagaries much more than the later ones. My first K1 had obviously been dropped after it was tacked together in the jig, and the welds (somewhere) broke: the gussets were then added to the now-misaligned frame and it was welded up sidesaddle, so to speak. When they got to the part where they installed the engine, lo, the bolts did not meet the holes in the engine cases. Their solution was to oval out the lower frame mount hole and widen the ones on the right-side triangular engine mount plates. When I got the bike, I could barely pull it up out of a deep turn on one side, and on the other I could not push it down and hold it down: it turned out to have the rear wheel about 1/2" out of line with the front one. I have some of those details mentioned in the chassis section(s) of my book, to help others watch for these sorts of things: this was the mad rush to build these bikes, in their day. ;)
« Reply #21 on: December 11, 2013, 09:57:58 PM »
No, not at the steering stem: back by the gusset plates where the rear loop(s) meet the triangle of the rear footpeg/pipe mounts. There is a small hole on each side of the gusset area, and there should be a small opening in the downtube of the rear loop there, normally seen above the points where the rear triangle (horizontal) tube meets the frame. It will look intentional, like they made the hole in the downtube too tall as compared to the diameter of the tube from the footpeg/pipe horizontal tube (does that make sense?).
  • Youngish
« Reply #22 on: December 11, 2013, 10:06:12 PM »
Yea, I think I know where to look. I'll try and take pix if when I find them, then I'll drill the "quiet memo" holes. Thanks for the info! There is just sooooo much to learn about these bikes. Fun!
  • Youngish
« Reply #23 on: December 13, 2013, 08:18:00 PM »
I looked real close, no luck finding them yet. I sprayed a lot of CRC in the holes showin in the first post pix here, and it started to overflow out the same hole. I guess I will have to bring it out in the daylight this weekend and look with a mag glass.
Offline martin99
  • UK Based, Non-
  • Adventure before Dementia
« Reply #24 on: December 14, 2013, 12:56:39 AM »
Don't want to turn this into a powder coating thread - or upset the professional powder coaters out there - BUT -
This is exactly why you need to be wary of buying bikes with powder coated frames. Those drain holes often get filled up. I had one recently with a two inch split in the lower frame rail, completely undetectable when covered in PC and only found it when the frame was blasted. That split had to have been there before the PC.
I'm not against powder coating - just make sure it was done by someone reputable with knowledge of motorcycles and not someone who coats railings for a living.
Build threads:
1977 CB750 F2
1958 Norton Model 99
