Author Topic: Esoteric CB500/4 question  (Read 1280 times)
Offline Spark6
« on: December 10, 2013, 07:02:04 PM »
Hey all, I asked this question over on dotheton.com, and it was suggested that I might find some good answers over here. I'm horrible at using the search function, so if I'm missing an obvious answer, I'm sorry for cluttering up your board!
I've got a CB500/4 project which was coming along quite nicely until it turned out that the cush drive in the rear wheel was rust-welded into the hub, meaning that I cannot replace the destroyed wheel bearings, or true the wheel. I even caved and took the wheel to a reputable shop, and they finally threw in the towel, charged me for as little as they could, and suggested I source a new wheel. In doing some research, I found that the CB500T has a different rear hub than the 500/4, and that got me thinking... does anyone know if they are interchangeable? If so, I'd just lace a CB500T hub (which seem to be far more plentiful than 500/4 hubs) onto my rim and call it a day... does anyone have any thoughts?
The guys on DTT pointed out that CB550 hubs are identical to CB500/4 hubs, but before I just replace a part that seems like it might be poorly designed, given the way its frozen up, I figured I'd see if I can use a simpler unit (no cush drive) from the 500T instead...
Thank in advance!
Offline Mo
Re: Esoteric CB500/4 question
« Reply #1 on: December 10, 2013, 07:42:11 PM »
Also, my understanding that the clearance difference between the 550 and 500 would require a different sized spacer in order to fit properly.
Offline Spark6
« Reply #2 on: December 10, 2013, 08:00:56 PM »
Oh, I didn't realize that the 550 and 500/4 hubs were different. (doh.) So I'd have to get some sort of spacer machined to get the chain to align properly/shim the 550 hub into the 500 swingarm?
I'm not sure where I'd find an ultrasonic cleaner (or even what that is!)... I always prefer to make old parts work again when its practical to do so, but that sounds like it might be slightly out of the scope of my little shop in the garage...
Offline Spark6
« Reply #3 on: December 10, 2013, 09:29:12 PM »
Ahhh, now I'm with you - thanks for the clarification, I'll keep that in mind if I end up going the route of a 550 hub.
I'll have to unlace the hub from the rim when I get a chance, and see what my options are with any local shops. I suspected that was what an ultrasonic cleaner was, but wasn't sure.
I appreciate the help!
« Reply #4 on: December 10, 2013, 10:39:39 PM »
Two points:--
(1) You have removed the L/H thread bearing retainer before attemting to get the sprocket hub out havent you?
(2) only the 550 hubs 77/78 are different all the 500/550K from 71 through 76 are identical
« Reply #5 on: December 10, 2013, 10:51:10 PM »
does the shop know these bikes have a left hand thread retainer?clockwise undoes it,once thats off these no way anyone with some skill couldnt get the cush drive apart no matter how gummed up/rusted/butched or otherwise stuffed.
Offline Mo
« Reply #6 on: December 10, 2013, 10:52:53 PM »
The wheel spacers are stock. His point was: use a 550 hub, use 550 spacers. 500 hub, use 500 spacers.
This and what brianj said!
« Reply #7 on: December 10, 2013, 10:59:11 PM »
the early 550 hub is the same as the 500,the later 550 is different and uses different spacers and the brake plate aswell.
