Author Topic: Ugly Duckling CB750 K7 ***updated pics 02/07/14***  (Read 10644 times)
Offline BPellerine
Re: Ugly Duckling CB750 K7
« Reply #25 on: January 18, 2014, 06:49:12 PM »
you have made the tank work very well I like the oil tank as well can you run fenderless in TO don't think we can in nova scotia.bill
1978 CB 750K ard and webers
another anfob
Offline blue collar
« Reply #26 on: January 18, 2014, 07:18:27 PM »
To be honest i have no idea lol. I'll have to look into that. Probably not. Ontario has some bs road rules.
Offline snowman
« Reply #27 on: January 19, 2014, 08:40:26 AM »
Looks great. Given me ideas for my K7 build. I like the seat you chose, homemade or did you buy it?
Sent from my iPad using Tapatalk
When you say seat i'm assuming you mean the "cafe" tail section? Yes i did make it. I made a 1/4 inch round bar "frame" and then covered it in sheet metal. I wanted to mirror that (not so pretty) K7 tan by using 5 panels. The main focus was having a flat top to mirror the flat top of the tank.
When you say that you made a "1/4 inch round bar frame" I assume it's separate from the hoop welded on the back. It would be great if you could post some details/pics.
Thanks
Offline blue collar
« Reply #28 on: January 19, 2014, 04:50:08 PM »
Thanks
Yah totally. The frame hoop i bent out of 1 inch tube that i welded to the bike frame. The tail section i made using thin round bar (1/4 inch). Hard to describe. It's the same basic process (Dustin) Kott Motorcycles does his bikes.   I'll try and find some pics.
Offline snowman
« Reply #29 on: January 19, 2014, 05:17:37 PM »
Thanks would appreciate it and KOTT sure builds some awesome bikes. My favorite is the black CB750 cafe with the copper rims and accents.
Offline snowman
« Reply #30 on: January 19, 2014, 06:05:49 PM »
BC, I just went to Kott's website and found a link to the 3 videos he did on how to build a cafe seat. That's one interesting way of building a seat and now understand what you did.
Offline blue collar
« Reply #31 on: January 19, 2014, 06:30:58 PM »
Different for sure. I tried in fiberglass first and did not like how organic it looked (not precise enough).
Offline snowman
« Reply #32 on: January 21, 2014, 06:00:53 PM »
BC if you don't mind I've got a few questions. Here I go, what you use to bend the 1/4 round bar to the shape you wanted, did you build an entire sub-frame from the round bar and how is it fastened to the back section/hoop? Thanks for the help blue collar.
Offline blue collar
« Reply #33 on: January 22, 2014, 01:28:36 PM »
I used a "ring roller" to make the frame for the tail section. Then i welded a tab to the rear of the frame hoop and used a bolt to fasten in from underneath. The front portion is bent sheet metal and fastened under the seat with "jack nuts" very hard to explain, any not the lightest set up but it worked. Clean lines were more my focus than saving a few grams here and there.
Ring roller
i'll grab you some pics tomorrow night if you want to try this process.
Offline snowman
« Reply #34 on: January 22, 2014, 06:35:25 PM »
That would be great, thanks.
Offline blue collar
« Reply #35 on: January 23, 2014, 03:13:31 PM »
The first shot shows how a bent section of sheel metal goes under the factory seat cross member and is fastened with jack nuts and c/s screws.
the second photo shows my battery/electrical pan. The olty in the center/rear screw goes through a tab welded on the frame and threads into a portion of the tail itself. It's not quick release by any means; but three screws and the tail section is off revealing the battery and electrical components.
maybe not the best way, but the best i can come up with with limited time,money, and tools.
Offline snowman
« Reply #36 on: January 24, 2014, 02:18:56 PM »
BC, thanks for all the info. May have a few more questions as I progress with my build.
Offline Roach Carver
« Reply #37 on: January 24, 2014, 02:46:18 PM »
like it
« Reply #38 on: January 24, 2014, 03:44:16 PM »
Great work, bc.  Are you staying with a bare metal (clear coat) look or painting.  My vote is for clear to show off your work.
Offline blue collar
« Reply #39 on: January 25, 2014, 06:20:12 AM »
Offline blue collar
« Reply #40 on: January 25, 2014, 06:24:00 AM »
Thanks CB750C.R.F.
If my tank were free of dents and scratches it would leave it raw. The tail section is also not very true/clean and would look nicer finished. This was my first go at it. Next time i want to try it in Aluminum and will maybe leave it raw then :)
Offline snowman
« Reply #41 on: January 29, 2014, 06:00:39 PM »
BC, started looking around for a ring roller here in the Montreal area and I'm all up for trying to build my own seat but the price they're asking I could almost have a custom made seat made. Any help where you got yours would be appreciated. Thanks
Offline blue collar
« Reply #42 on: July 02, 2014, 06:38:36 AM »
Hey gents!
Been a while and life is crazy busy but here is an update of the bike. Ready to hit the road after some carb tuning and a plate.
I'm not totally happy with the upholstery ( I stitched it by hand, no machine). It does not flow with the tail section as much as i would like. Maybe less padding in that section.
Still some wires to tuck and tidy.
Re: Ugly Duckling CB750 K7 ***updated pics 02/07/14***
« Reply #43 on: July 02, 2014, 07:41:28 AM »
It came out great, bc. I'm not sure if you mentioned it in the string but did you do any performance mods to the motor? I see that you went with CRs so I was curious.
Offline blue collar
« Reply #44 on: July 02, 2014, 07:47:56 AM »
No sadly, at the time of building the engine i did not do any mods, and it shows. The CRs dont run the smoothest at low RPM on a 736cc . Defintely over-carbed. I'll do my best to get them ridable for the summer and maybe 836 the engine over the winter.
I got a deal on the carbs that i couldn't pass up.
« Last Edit: July 02, 2014, 07:50:59 AM by blue collar »
« Reply #45 on: July 02, 2014, 07:54:02 AM »
The CRs will definitely run better with a ported head, 836 and cam. You might run better for now on stock carburetors if you still have them. If not, no big deal. I ran my CR 29s before my engine rebuild.
Offline blue collar
« Reply #46 on: July 02, 2014, 08:07:19 AM »
What was your set-up (jets/needle) if you don't mind me asking.
Offline Prez1967
  • Adding lightness...
« Reply #47 on: July 05, 2014, 04:16:56 AM »
Excellent build!
I really like seeing what can be done with the '77-'78 tanks.
Would you mind sharing some info on your controls? Where did you get them from? Was hooking them up easy? (I'm new to motorcycle building/wiring).  I'd like to run clip-ons on my '78K and could use some new control switches as the factory stuff is a bit tired.  Any clearance issues with the clip ons and the tank?
Really digging the low profile gauges and the Dime City top tree!
Offline flippin
« Reply #48 on: July 05, 2014, 04:57:10 AM »
The bike turned out great, not a ugly duck at all!
Do you have some more information on the wheels and tires? Which brand and dimension is it? I have a similar bike that needs new wheels and your combo is just what I'm looking for.
Offline blue collar
« Reply #49 on: July 05, 2014, 08:06:29 AM »
Excellent build!
The controls are universal sheap-o ones from dime city. They dont simply plug and play, you have to become friends with your multimeter and make it all work together. Not my strong suit, but i got it done.
Clip-ons definitely don't clear the tank unless they are splayed way out, the way they sit now they rub a touch.
Thanks for the kind words
