Author Topic: Ugly Duckling CB750 K7 ***updated pics 02/07/14***  (Read 11255 times)
Offline blue collar
Re: Ugly Duckling CB750 K7 ***updated pics 02/07/14***
« Reply #50 on: July 05, 2014, 08:19:05 AM »
The bike turned out great, not a ugly duck at all!
Do you have some more information on the wheels and tires? Which brand and dimension is it? I have a similar bike that needs new wheels and your combo is just what I'm looking for.
Thank you!
The rims/hoops are from a Honda GL1000. They run the same 19f 17r as the Cb750 k7 & k8 but they are aluminum and over 1lb lighter per rim than the steel k7 & 8. They are also stiffer. The hubs are the k7 hubs. They pretty much lace right up with standard spokes.
The tires are Avon Road riders
Offline flippin
« Reply #51 on: July 05, 2014, 02:53:13 PM »
Thank you!
Thanks for the answer. I'm going for aluminum rims myself, after reading about some guys putting a 18" rim at the rear, I got a bit confused. I guess it easier to find tires, but then it gets harder to find the right spoke length. The Avons looks great, I've heard a lot good about them!
Offline akabek
« Reply #52 on: January 19, 2015, 07:20:51 AM »
Great job on the cafe.
Did you make any progress on your jetting?  Are you doing any mods over the winter?
I still have more tweaking to do on my jetting.  I ordered some air jets but the mail man missed my mail slot so someone else has them and it has been two months.  I will have to reorder them so I can get a head start this spring.  Once I get my air jets I will be all set to finally nail down the jetting on my CRs.
Maybe this summer we can meet up for a ride.....
« Reply #53 on: January 19, 2015, 09:27:29 AM »
Can you post any updated pictures after tucking in the wiring and your shakedown?
Offline ozpacman
« Reply #54 on: January 22, 2015, 04:11:31 AM »
BC if you don't mind I've got a few questions. Here I go, what you use to bend the 1/4 round bar to the shape you wanted, did you build an entire sub-frame from the round bar and how is it fastened to the back section/hoop? Thanks for the help blue collar.
Sent from my iPad using Tapatalk
The first shot shows how a bent section of sheel metal goes under the factory seat cross member and is fastened with jack nuts and c/s screws.
the second photo shows my battery/electrical pan. The olty in the center/rear screw goes through a tab welded on the frame and threads into a portion of the tail itself. It's not quick release by any means; but three screws and the tail section is off revealing the battery and electrical components.
maybe not the best way, but the best i can come up with with limited time,money, and tools.
Looking good Blue Collar!
I'm curious to know what the 4 digit number on the frame cross member represents.  My K7 is 2224.  Was that something unique to K7's or they all have that?
Russ.
