Author Topic: Cylinder Nuts Missing Washers? Help  (Read 2204 times)
Offline cakey
  • 5% recipe and 95% process
« on: December 11, 2013, 07:13:44 PM »
Can't believe it everything was going great until I realised there is no washers underneath the cylinder head nuts. I didn't forget them because none came off the studs. I have everything all gaged up and labelled with photos as it came off the bike.
They are the Ape studs and I have torqued to 20 ft lbs.
Do I have to have the washers?
If I get washers can I replace one stud and re torque at a time instead of undoing the whole head?
I picked up on it when I was referencing Honda mans booked and double checked CSMNL. I am pretty sure they should be ther.
Please suggestions? Bugger just can't win at the moment
1971 CB750 K1 (restored)
1975 GL1000 Goldwing (restored)
Offline cakey
Re: Cylinder Nuts Missing Washers? Help
« Reply #1 on: December 11, 2013, 08:14:09 PM »
So the local nut and bolt shop has some hardened zinc washers.
Honda spec is
 E-04    90485-035-000        Washer, 14mm    ID 8mm   OD 18mm    thickness 2.3mm    Zinc
The local shops specs are ID 9mm. OD 18.5mm. Thickness 2mm. Hardened zinc
Is this to far out?
« Reply #2 on: December 11, 2013, 08:42:29 PM »
Why not order from Honda and be on the safe side?!
Offline cakey
« Reply #3 on: December 11, 2013, 08:46:36 PM »
Can only order via Japan. If in stock then they will order from Japan after 23rd December.
I am going to try and find some second hand ones instead of using wrong size.
My main question now is how I am going to put them on.
Do I loosen the 6mm bolts and then undo the lot and re torque or will this stuff my gaskets?
Or do I do one stud at a time to not stuff the gaskets?
I just don't know
« Reply #4 on: December 11, 2013, 10:25:51 PM »
doing one stud at a time on a gasket that has not run is what I would do (and i have been doing the job over 40 years) also those local ones are only 0.3mm or 12 thou thinner so i would use them
Offline cakey
« Reply #5 on: December 11, 2013, 11:32:40 PM »
By the time I read your post bryanj I had already decided to loosen them off across the board. My reason owning was that if I did decide to loosen them then the sooner the better for the gaskets. Also the engine had not been run so I thought it would be safe. Also I am going up in small increments for the Ape studs so I thought that by the time I adjusted the torque wrench 8 times for 16 nuts it would do my head in and I might not get as even a torque doing it one at a time.
I am worried that the local washers from the shop might not fit in the recessed parts in the head if they are larger outside diameter than original.
« Reply #6 on: December 12, 2013, 05:35:50 AM »
Good idea as you can call it a re-torque which will help the gasket bed in better. Also having washers may change the torque numbers also because of friction differences.
Offline Bodi
« Reply #7 on: December 14, 2013, 09:30:10 AM »
Hardened zinc? Zinc can be hardened?
What are the OEM washers made of? Zinc is quite soft - could be an advantage in sealing but I believe the Honda washers are steel, much harder than zinc. Would the stud force be enough to crush a zinc washer?
I use zinc washers as sacrificial anodes to reduce corrosion, but I haven't ever considered the stuff good for high tensile fastener washers.
« Reply #8 on: December 14, 2013, 09:35:25 AM »
Yeah, zinc might loosen up since it is soft due to expansion/contraction and probably wouldn't hold the torque as well as the Honda ones which are probably?? hardened steel.
Offline lucky
« Reply #9 on: December 14, 2013, 11:19:19 AM »
A washer is very important.
It acts as a spacer.
It acts as a bearing surface.
It acts as a corrosion prevention device.
It can be a locking device.
Offline cakey
« Reply #10 on: December 14, 2013, 01:16:41 PM »
I ended up spending an hour at the motorcycle wreckers going through their buckets of washers. I found 16 that had the right dimensions. Re torqued back down and felt totally different this time.
