Author Topic: F2 transmission in K6 case  (Read 2612 times)
Offline EnginebyAdam
« on: December 14, 2013, 06:41:15 AM »
I have been trying to find this info on the site but am coming up short. I want to use a F2 transmission in the K6 cases I have. The F2 would give me the gear ratio I am looking for and the longer output shaft will help with setting up the slick on the rear. I know that K6 and F2 had the double row bearings but as far as I can tell the F2 case is different?
Thanks in advance.
Better Rodded Than Rotten
Offline bjbuchanan
Re: F2 transmission in K6 case
« Reply #1 on: December 14, 2013, 08:37:28 AM »
Thanks in advance.
I can't give you actual advice but if you have no answers here post in the HI-PO/racing section, bet it has been done there
« Reply #2 on: December 15, 2013, 02:20:44 PM »
I've come up empty asking before, my brother claims to have done it with an F0 trans. I have an F2 trans that is backcut, the next case I split will get it. I think the K6 has the correct machining for the wide bearing. Hopefully someone knows for sure.
« Reply #3 on: December 15, 2013, 06:18:48 PM »
This post shows the F2 gears being swapped in with a K6 transmission, but does not mention about the output shaft.
http://forums.sohc4.net/index.php?topic=82708.0
Offline BPellerine
« Reply #4 on: December 16, 2013, 06:11:18 PM »
I think that the k8 and f2/3 share the same output shaft but diff in the upper gears.there are stronger clutch springs in the f2/3.they went to the bigger 630 chain on all 77/78 750k/f
1978 CB 750K ard and webers
another anfob
« Reply #5 on: December 17, 2013, 06:11:20 AM »
I may just end up grabbing an F2 transmission and swapping in 4th and 5th like the link I posted. I can always run a offset sprocket on front, and possibly rear if need be for alignment.
Offline BPellerine
« Reply #6 on: December 17, 2013, 05:53:37 PM »
just a Q but would you make it to 5th gear on the 1/4 mile with a big motor revving high Terry in Australia has done 115 in third gear with an 836.bill
another anfob
« Reply #7 on: December 17, 2013, 06:01:57 PM »
I asked the same question to Jon Weeks because I found with my dohc that I was shifting to fifth right on top of the 1/4 mark. He figures all five are needed, so I'll plan as if they are ;)
« Reply #8 on: December 30, 2013, 11:14:09 AM »
Just wanted to bump this up.
Now that the 180/55/17 gsxr wheel looks to be the setup I am going with, I'm really interested to see if I can swap in the longer F2 output shaft to help with alignment.
« Reply #9 on: December 30, 2013, 01:01:27 PM »
I would like to know this as well...?
« Reply #10 on: December 30, 2013, 03:12:50 PM »
I have a project to finish before splitting a case but I'll check a K2 case wen I'm able to stop grinding chrome moly in the shop.
« Reply #12 on: December 31, 2013, 12:47:03 PM »
This was just posted on ebay. '78 cb750F case and has the double groves for the output bearing ???
http://www.ebay.com/itm/1978-honda-cb-750-f-honda-750-four-engine-cases-/301055133353?pt=Motorcycles_Parts_Accessories&hash=item461848c6a9&vxp=mtr
I sent both of the ebay sellers with the "F2/F3" cases a message asking for the serial numbers off the cases to see if they are indeed both F2/F3 cases. Should help clear this up a little if they get back to me.
Offline BPellerine
« Reply #13 on: December 31, 2013, 03:42:19 PM »
78k cases have the double groove as well adam.bill
another anfob
« Reply #14 on: December 31, 2013, 05:14:06 PM »
Good to know Bill, thanks.
The seller with the second set of '78F cases I posted gave me cb750E-3107922 which indicates an F3 engine. Which makes sense for the two grooves in the cases.
« Last Edit: December 31, 2013, 05:37:08 PM by EnginebyAdam »
