Author Topic: Carb slider don't want to come out!!!  (Read 1877 times)
Offline jpfrk2001
  • I hate being a
  • What was that!
« on: December 15, 2013, 10:03:26 AM »
Hey all, Im working on my carbs right now. It is a 1978 CB550F
I am working on tearing #1 apart. I got all the way down to trying to remove the slider/needle assembly from the body. It appears to be "stuck" Don't want to come out. Im going to mix up a cocktail of 91 octane, seafoam, Marvel Mystery oil and let is soak for a day. Im hoping that will do the trick.
Any one else have any advice. What am I missing? I do have the Service Manuel downloaded for reference. But I think It gives instruction for a completely different carbs.
Mine are the Keihin PD ones.
Hierisluv?
I do tasks the most difficult way. My life is interesting.
1978 750K
1978 550K on a table
2009 Ducati Monster 1100
77/78 cool 2 member
Re: Carb slider don't want to come out!!!
« Reply #1 on: December 15, 2013, 10:13:41 AM »
Before you make the gas bomb try some heat from a heat gun if the slide is stuck from maybe some gas residue/varnish.
Offline MoMo
  • Ride like you're invisible
« Reply #2 on: December 15, 2013, 10:15:39 AM »
Yep, usually the easiest and fastest method is the heat gun...Larry
« Reply #3 on: December 15, 2013, 10:21:33 AM »
Substitute laquer thinner or zylene for the gas. Gas is what made it like that. Heat can be the secret but patience is critical, the posts are easy to break off. If you get any movement go back and forth to work the carb cleaner in and be careful to not mushroom the ends of the pins or bend them.
 When you walk away the carb cleaner dries and the varnish grabs again. I'm working on a set that had the fuel left on for years. Looks like the labrea tar pits inside. I think there was a dinosaur bone in there.
Offline jpfrk2001
  • I hate being a
  • What was that!
« Reply #4 on: December 15, 2013, 10:51:19 AM »
Ok, thanks guys. I will go get a heat gun today.
And to late on the gas bomb. Already made, Carb is fully soaking right now, covered up with a lid, sitting in the sun. How's that for a gas bomb?  :D
1978 750K
77/78 cool 2 member
Offline MoMo
« Reply #5 on: December 15, 2013, 10:55:01 AM »
Yea,  use a lighter instead of the heat gun, it'll come apart read quick :P...Larry
Offline jpfrk2001
  • I hate being a
  • What was that!
« Reply #6 on: December 15, 2013, 11:16:18 AM »
Most definatly going to use a open flame, heat gun, with a bottle of NOS slowly purging to add more oxygen content. All working in my shop, on a wooden work bench!!
haha.
Seriously, I will wait for the gas mixture to evaporate before applying heat. I may use my compressed air to aid in this.
1978 750K
77/78 cool 2 member
« Reply #7 on: December 15, 2013, 01:54:51 PM »
I have contacted Homeland Security-----------------------   ;D ;D
Offline jpfrk2001
  • I hate being a
  • What was that!
« Reply #8 on: December 15, 2013, 02:46:30 PM »
haha.
Ok, I got it out. Then I dropped the carb back in the cocktail. Still gotta get a little spring out in one area, and a o-ring in the other area.
AND.....
I stripped one screw head trying to remove the needle from the assembly!!! Had to turn it upside down, drill it out from the backside. I was able to get it out and did not damage any threads.. So..
Were is the best place to get replacement hardware?
Im thinking of a RC Car and airplane store.
Any one?
Im really buggering this up. Not even done with my first carb. Still have 3 to go. And I am already searching for replacement hardware. Great times!!
1978 750K
77/78 cool 2 member
Offline jpfrk2001
  • I hate being a
  • What was that!
« Reply #9 on: December 15, 2013, 03:06:14 PM »
Size is M3 x 8
1978 750K
77/78 cool 2 member
« Reply #10 on: December 16, 2013, 07:13:16 AM »
Size is M3 x 8
your local HW store  ;)
Offline jpfrk2001
  • I hate being a
  • What was that!
« Reply #11 on: December 16, 2013, 10:46:39 AM »
Size is M3 x 8
I hope so. Im going to stop at Ace on the way back to work. Taking the slider with the good screw installed. I will buy a batch to cover the other 3.
1978 750K
77/78 cool 2 member
Offline jpfrk2001
  • I hate being a
  • What was that!
« Reply #12 on: December 16, 2013, 12:56:28 PM »
Just for some info for all of you:
The size of the little screws holding the needle in the slider is a M3 x .50 x 8mm
Ace Hardware was able to rescue my Ass. But appearently you will be getting 2 MM Allen head button screws. So, you will need to go get a hobbiest 2mm allen driver. Look into  Horizon hobby for this tool or your local RC Hobby Shop.
1978 750K
77/78 cool 2 member
Offline rb550four
« Reply #13 on: December 19, 2013, 05:54:43 PM »
  Were you able to get the floats out? Sometimes you can't get the pin hot enough with a heatgun without risking damage to the float, in this case I use a soldering iron on the brass between the floats , it gets the pin warmed up enough to weaken the varnish allowing movement with little force. Like Don R said the posts can break off easily and it requires patience.
Offline bjbuchanan
« Reply #14 on: December 19, 2013, 08:52:13 PM »
I like to use xylene, it is some badddd stuff. It will eat all that varnish and everything else like a fat kid in front of a carvel cake. Just don't get it on your hands, very uncomfortable feeling until it is washed off well. Nasty head buzz too if you linger over it for a bit but it cleans well
Offline oldschoolcarbs
    • OldSchoolCarbs
« Reply #15 on: December 20, 2013, 09:51:08 AM »
If you send me a SASE I'll give you enough M3 screws of the proper variety--JIS with captive lockwasher.
Find my info here: http://www.oldschoolcarbs.com
Not to be pushing stuff but I've also got JIS driver sets, which any Jap bike owner should have.
Jack
« Reply #16 on: December 20, 2013, 11:12:51 AM »
I worked at factory once were we had a 55 gallon barrel of xylene at all times on hand for cleaning purposes. One of the guys there got hooked huffing that stuff, remember him always having a bottle of it and a rag in his car. Wonder what his internal parts look like nowadays if he is still alive.
