Hi newbie here,
Just got a 81, cb650 block from craigslist and bolted it to a table. Using it for a custom project but I wanted to get it running first. (Don't have a frame yet...) I got the headers on there and hooked up the carbs. I'm assuming compression and valves are fine for now because I don't have a comp tester and I don't want to take the head off just yet.
I retrofitted a set of carbs from an 83-85 with some hose and cleaned them up real nice, I have plenty of experience with the japanese carbs and plan on tuning them to the 81 block. My question is, don't the cv carbs need a good seal to run at all? The CV slides/needles won't move (engine won;t run right) if theres not an airbox/filter on the outside of the carbs right? (air filters are expensive and I don't wanna drop the 120 yet.) I like the look of 4 filters, but if someone can convince me that the stock airbox can perform the same I'm all ears.
![Tongue :P](http://forums.sohc4.net/Smileys/default/tongue.gif)
After the carbs and pipes were hooked up I started messing with the wiring. which I don't know much about. I found a good wiring diagram, along with the free manual online and got to work plugging stuff up. Today I was able to jump the starter motor off of my truck and hear it turn over (nothing is seized!!), but I could not get a spark from the coil. I don't have the right hand controls, so I shorted the connections in the wiring harness with a paperclip, connection black to black/white. This is what the killswitch does when it is in "run" correct? Why am I not seeing a spark when the engine turns over? Also to engage the starter I am shorting the big red on the starter relay to the starter + cable. Why can I not use the paperclip trick on the right hand control harness connecting the yellow/red to the black? This should do the same thing as a starter button but nothing happens. Have tried both "run" and "start" paperclips at the same time, still nothing.
I have ordered right hand controls (killswitch) and they are on the way, but according to what I tried today I am not confident it will help... I think something else is up. What are some common problems/mistakes that I could be making?
Sorry for the overload just wanted to give you the details.
