Guys, the 74 CB750 is back together and the wiring is getting close. This is my first rebuild of a dry sump engine. Every bike I've rebuilt in the past had a crankcase where oil was filled and checked through the dipstick hole. You "knew" oil was in the crankcase and transmission because you could see it. On the 2 strokes, you simply add oil to the start-up fuel and make sure the tranny is lubed.
I've removed the plugs, I've added about 3 quarts of Motul 10/40 and I've kicked it over several times. I don't have any oil pressure showing and the oil tank is not going down like it should. I've added one of Terry's oil coolers and I figure a good 1/2 quart for it and the filter.
I'd appreciate some suggestions on getting some oil pressure before I start it up and run it. My CB500's oil light will go out when kicking iit over, so the oil pressure should come up during a kick once primed.
Thanks,
Gordon
