Author Topic: Odd cam / rocker findings  (Read 1114 times)
Offline Garage_guy_chris
« on: December 17, 2013, 10:37:31 PM »
I decided to pull the valve cover tonight and i am again confused. I have two odd things i dont know what to make out.
The Rocker arms:
 the rough parts of the casting appear to have been ground and cleaned up. Never heard of or seen this done before seems a little odd to me?!?
The cam:
there is a "R7" and a "AE" cast into it.
I did a few rough lift measurements to the cam while in the head and came out with some odd measurements;
base circles measure out at about 1.000" inch manual specifies  1.1016" - 1.1030"
lobes measeure out at around .315" intake and .315" exhaust manual specifies .315" intake and .286" exhaust
Im thinking this is a regrind of some sort but it seems odd the base circle is .100" undersize which for something like a cam seems like a ridiculous amount to grind away if in fact its a regrind....
Looking at my cam and comparing to ebay or whatever its obvious its been reduced there is no longer a grove between lobes its been ground down to its root diameter
« Last Edit: December 17, 2013, 10:44:44 PM by Garage_guy_chris »
AJK
Re: Odd cam / rocker findings
« Reply #1 on: December 18, 2013, 03:07:37 AM »
The previous owner has tried to lighten the rockers for high rpm performance.
« Reply #2 on: December 18, 2013, 08:20:32 AM »
IMPORTANT..check and Write Down your valve clearances BEFORE taking apart.
Yes lightened rockers..motor sure has stuff done...
« Reply #3 on: December 18, 2013, 08:30:22 AM »
Ok the rockers are a little odd in my mind i dont think its going to effect a whole lot they seem in otherwise great condition. What does seem more odd and i would hope to get some insight on is the cam in this thing. I will probably have some more photos of later today
The cam:
lobes measeure out at around 1.315", 1.315 - 1.000 = .315" intake and 1.315", 1.315 - 1.000 = .315" exhaust manual specifies .315" intake and .286" exhaust
« Last Edit: December 18, 2013, 09:25:11 AM by Garage_guy_chris »
« Reply #4 on: December 18, 2013, 08:39:52 AM »
It may be a mystery cam and have markings unknown to us on here, that is why you record the clearance.
 I hope you did the first check on cams,and removed the end washer....
« Reply #5 on: December 18, 2013, 09:15:55 AM »
I forgot to mention i did take off the end bolt and washer, nothing out of the ordinary just the 6 dash marks that are talked about and common on the factory castings.
I also looked at the flange for the sprocket there is nothing there either.  based solely on lift it appears to be a mild cam i will have to make up a rig to check out the duration and get an idea on opening / closing angles.  Im leaning towards using it provided the issue with the base circle being way undersized isnt going to cause a problem of throwing out the valve train / rocker geometry.  later today im gonna turn the engine over and watch what kind of arc the adjuster and valve stem follow it looks awfully steep with the valve closed
I will measure valve clearances as suggested on cyl #3 and #4 as i haven't touched that side yet.
Worst case i have to replace the cam. soon enough i should be able to draw the entire picture of what has been done to this engine. Maybe able to figure out what the previous owner was trying to accomplish.
« Last Edit: December 18, 2013, 09:18:49 AM by Garage_guy_chris »
« Reply #6 on: December 18, 2013, 09:25:45 AM »
Any wear on the valve cover caps ?
 What everything is indicating to me is a very labor intensive effort but low dollars spent, and not real radical (good for street)
« Reply #7 on: December 18, 2013, 09:37:39 AM »
Thanks for all the help it is much appreciated.
I would agree with this completely in every aspect of what i have found regarding the whole bike thus far.
I just checked. At the bottom or 6 o'clock position on the valve cover inside the inspection/adjustment openings there is contact marks on most and a groove on the #1 intake opening that seems to match up to the adjuster screw.
I can take and post photos if it helps.
« Last Edit: December 18, 2013, 09:39:44 AM by Garage_guy_chris »
« Reply #8 on: December 18, 2013, 01:11:35 PM »
What's the serial number of the engine?
« Reply #9 on: December 19, 2013, 10:05:39 AM »
the serial is CB750E-2350454 which puts it as a 1974 K4
If you see my other thread http://forums.sohc4.net/index.php?topic=132705.0  I have just discovered furthur problems which are now going to require a rebore or a cylinder swap.  So now i have lots of time to figure this out and sort everything
« Last Edit: December 19, 2013, 10:08:38 AM by Garage_guy_chris »
