Hi All,
I will put a few questions in one spot, and see if you can help me.... And yes, I have used the "search" function.
I want to re-lace the wheels. The front I can find spokes for no problem, but the rear seems to be somewhat of a pickle. After finding this post
http://forums.sohc4.net/index.php?topic=71439.140;wap2I am under the impression that the 77's are a little unique.
Has anyone found a set of SS or Cadmium spokes to fit a 1977 CB550F Rear Hub? Yes, I can buy OEM, but for $2+ a spoke, that is a little much. Plus, they are not SS or cadmium.
Tongued Washers...
How do I remove/ work around/ properly bend the tongued washers that hold the rear sprocket to the wheel? I don't really want to trash them in the removal process. I have looked, but have not come across a decent answer. Most references are "when I finally figured out how to undo them" blah, blah, blah, that don't actually tell me how.
Carb question... I took the bike out for a spin the other day. It won't really rev above 5k and it really doesn't generate power up hills. I noticed that at about 3/4 throttle, it is still burning fairly well, but when I go past that, it starts to bog down. Now, I am new to all this, so frankly, I am a bit intimidated to start getting into the carbs. No, I have not removed them, and no, I have not cleaned them. I am just trying to get my head around what these symptoms might be indicating. And then, when I get enough courage, I will pull them out and get on cleaning them. I am running the stock airbox and have made no mods or changes to the intake system.
What is making the bike run like this? Rear Sets.... I am not much of a metal fabber. I would like to put some rear sets on, but they all seem to require me to build some form of bracket to mount them to.
What is a good set of rear sets for the 550F that don't cost a small fortune? I am willing to put some money into these parts, but considering I spent $550 for the bike to begin with, I don't really want to spend $300+ on Raask which seem to be the only ones that offer a mounting plate with the kit. Or, what kind of solution did you come up with that did not involve welding, forging, or machining brackets? Any modern bike ebay finds that worked out?
Clip-Ons.... Now that I have your attention, and you have read this far.
What clip ons do you like? This may be like asking you who your favorite child is, but I am just curious. The guys at
http://www.twinlinemotorcycles.com/ recommend Woodcraft. It seems like there are lots of them out there, but I didn't know if there was a brand that stood out above the rest.
Seattle People...
Know of a good shop in Seattle area to powdercoat the rims? I want to go with a nice black rim, chrome spokes and polished hubs. I like the look, but was wondering who had good luck with somebody in my neck of the woods.
Thanks for any and all answers. -R
