Author Topic: CB650 WONT START WHEN COLD  (Read 1560 times)
Offline bullett500
« on: December 19, 2013, 04:57:49 PM »
My 1981 CB650C will start instantly when the temp is above 70 degrees.  Below 60 and it wont start at all without a shot of starter fluid in the air flilter.  Any ideas?
Offline LesterPiglet
  • 1977 CB550F2
Re: CB650 WONT START WHEN COLD
« Reply #1 on: December 19, 2013, 05:07:44 PM »
Use the choke. :-D
Offline tomkimberly
« Reply #2 on: December 19, 2013, 05:34:34 PM »
With the key off, twist the throttle twice, pull choke cable full all the way out, turn key on, hit starter button, it should fire right up.
Tom
Offline bullett500
« Reply #3 on: December 19, 2013, 05:47:45 PM »
I've done that.  If I follow that exact routine about 20 times, sometimes it will start, but not very often.  It hits a couple of times then just turns over.
Offline tomkimberly
« Reply #4 on: December 19, 2013, 06:51:44 PM »
Then you need to clean your carbs, mainly the slow jet circuits.
What I did with my 81 was to replace the VB44A carbs with VB44B carbs (VB44C's will work as well) as they have screw in pilot jets.
Tom
Offline cb650
« Reply #5 on: December 19, 2013, 08:23:50 PM »
Check the fuel auto shut off too.
Offline MoMo
  • Ride like you're invisible
« Reply #6 on: December 20, 2013, 05:33:31 AM »
Also, make sure the choke cable is actually working- it may have become unhooked at the lower end...Larry
