Author Topic: Swing arm movement on 750 k2 ???  (Read 1078 times)
biketaviousmaximus
« on: September 03, 2006, 05:16:23 PM »
Hi guys, my first post here, I have searched the forum but havent found an answer.  My swingarm slides from side to side about an eigth of an inch, is that meant to happen? Is it as simple as undoing the nuts on the frame and packing it with washers???
Hope you can help? biketaviousmaximus aka Paul (Australia) 'Tasmania'
Offline mcpuffett
Re: Swing arm movement on 750 k2 ???
« Reply #1 on: September 04, 2006, 01:40:06 AM »
you may need new swinging arm bushes,   mick.
Offline petercb750
« Reply #2 on: September 04, 2006, 02:19:22 AM »
If the sideways movement is at the pivot end of the swingarm (which from your description sounds like it might be), might it be missing the end caps that fit over each end of the pivot rod? I replaced my bushes a while ago, and as we were refitting we noticed we had sideways play, and realised that the end caps were still on the bench. deerrrr. Putting them in properly should be a tight squeeze and no sideways movement.
If the movement you've got is at the axle end of the swingarm (ie back wheel can move sideways a bit) then that would be bushes and/or worn pivot rod.
Anyway, just my thoughts.
Peter. (have sent you a PM Paul).
1972 750/4 K2 (his), 1976 400/4 (hers)
1982 CB1100RC (ours)
