Author Topic: CB750 engine numbers & Crankcases  (Read 7899 times)
Offline 01Thomas
« on: December 25, 2013, 08:33:58 AM »
Hi everyone
I have bought a joblot of CB750 spares, among them crankcases with the following numbers (all prefaced by CB750E- ):
A: 1035897
B: 1097878
C: 2071504
D: 2522058
E: 2551078
Going by the info in Pete Shoemark's book "Honda CB750 SOHC Super Profile" (*1), case #A is a K0, #B is a K1 and #E is either a K6 or F1. Is this correct, and could anybody fill some of the other blanks?
How accurate is Shoemark's book in general?
Is there anyway to tell if any particular upper & lower crankcase halves constitute a matching set?
Finally I wish you all a Happy and Merry Christmas!
Thomas
(*1) published by Haynes in 1983.
1971 Honda CB750 Four K1 [Engine: CB750E-1113521 / Frame: CB750-1113838]
1977 Seeley Honda CB750F (F1) [Engine: CB750E-2551214 / Frame No: SH7-655F]
'96 Yamaha YZF750SP & '81 Moto Guzzi SP1000 & '80 Moto Guzzi 850 LeMans II & '82 Bimota KB-3 [Frame No 49] & '66 Ducati 50 SL/1 & '53 Miele K-50 & '38 Miele 98
Offline mrbreeze
  • Not your average
Re: CB750 engine numbers & Crankcases
« Reply #1 on: December 25, 2013, 09:30:43 AM »
Not familiar with that book but there is a handy reference page on the Honda chopper site. You could check your findings against that.
MEMBER # 257
Offline Bowswell
  • CB750K1,CB750 K4,CB350F,CB400t1,meanstreak
Offline Dream750
« Reply #3 on: December 25, 2013, 11:45:10 AM »
Never seen the Pete Shoemark book. ???
These are the Honda (published) engine serial numbers that I have:
750 K6: 2428762 to 2476663
750 F1: 2515094 to 2563530
Going by the Honda engine serial numbers, your 2551078 would be a 750 F1
Offline mrbreeze
  • Not your average
MEMBER # 257
« Reply #5 on: December 25, 2013, 05:49:57 PM »
http://www.satanicmechanic.org/enginemods.shtml
I wonder: are those the mods for Euro bikes, or something? They aren't anywhere close to my old notes. It seems 'sketchy'.   ???
Just one example: there are 4 distinctly different clutches. There were 2 in the K0, another that happened late in the K2, and the final [major] change to the F0/K6 bikes that stayed to the end. Those don't show up on the list, except an obscure reference to "7 plates instead of 8" during the K0. (?)
The crankcases changed 4 times, too: the sandcast not being counted, here (it had 3 of it's own cases before diecast ones came along). The cases changed during the K1, again partway through the K2, at the K4, and for the F0 and again for the K7/F2.
« Last Edit: December 25, 2013, 05:54:42 PM by HondaMan »
Link to website: SOHC4shop.com  (Note: no longer at www.SOHC4shop.com, moved off WWW. in 2024).
Offline Jonny0865
« Reply #6 on: December 26, 2013, 05:52:17 AM »
Hey everyone, I am kind of lost with identifying my cases. I bought this engine on eBay and the guy said it was a '76 cb750f. I know the 76 f's and the 78 k's are almost identical, but when I try to match up the numbers I cannot figure out which one it is. I have it all in pieces for a complete rebuild and I would like to get it strait before I learn the hard way.
« Reply #7 on: December 26, 2013, 07:59:45 AM »
Here is another popular chart. Yours looks to be a K8      http://www.hondachopper.com/engine/engine_timeline/timeline.html
« Reply #8 on: December 26, 2013, 09:43:06 AM »
According to the US Honda ID book i have the only engines starting  with a 3 are 1978 K8 models
1976 F starts at 2515
1972 K2 starts 2000
1970/71 K1 starts104
1969/70 K0 starts 1000
« Reply #9 on: December 26, 2013, 09:49:34 AM »
Is that case an sohc ? Number pad looks very far ahead..
 Ah i see it now its the late ones with the number boss nearer to the middle and turned 90degrees.i have only seen a few of those and I think the front motor mount is separate, on left side and comes off..
Offline Jonny0865
« Reply #10 on: December 26, 2013, 09:54:22 AM »
754 it is a sohc. I could never really get any exact answer because I read that honda took 76f motors and began to use them for 78k motors but I'm not sure how interchangeable the parts are. Should I look specifically for 78k? Thanks guys
Offline Jonny0865
« Reply #11 on: December 26, 2013, 02:29:58 PM »
Also, I checked the pistons (slight dome) and they are all stamped 392. I checked cmsnl and it says CB750F.1.P. Now this is really making me wonder. I know this engine is stock but can the case be a 78k but the pistons and head/can are from the 76f?
« Reply #12 on: December 26, 2013, 04:22:16 PM »
1978 K model 750 uses a 392 piston also---3101-392-020
Offline Jonny0865
« Reply #13 on: December 26, 2013, 04:40:18 PM »
Safe to say it's a 78k.... Thank you ekpent! Are there other ways to id a motor besides SN and piston number?
« Reply #14 on: December 26, 2013, 05:22:54 PM »
Used motor could have things changed, just got to go over stuff, and check.
Offline Jonny0865
« Reply #15 on: December 26, 2013, 09:07:51 PM »
That is true. I just have to go piece by piece. This is my first rebuild so I don't wanna make any mistakes and have it cost me down the line. I appreciate all the help
