Author Topic: 1977 CB550F Restoration  (Read 26629 times)
Offline dagersh
    • Photos
Re: 1977 CB550F Restoration
« Reply #75 on: March 24, 2014, 10:13:41 AM »
No those won't work without them....  that is a potentially a real PITA.
Contact harrisuluv on here, he may be able to help you out with some parts.
Calj -
Every bit as beautiful as SohRon's restoration, and in my meager opinion, that is the Gold Standard I've seen. Not to say other bikes and builds aren't gorgeous, just this level of restoration is really uniquely beautiful to me.
A huge fan-
I spent some time over on SohRon's resto thread...  I appreciate the compliment, but must defer to him.  My stuff looks amateurish in comparison.
Gersh
1962 CA95
1966 Black Bomber
1966 CA77 Dream
1967 Superhawk
1970 CB750K0
1972 CL350
1972 CB450/500 Custom
1972 CB500K1
1975 CB550F
1976 CB400F
1975 CB750 Future Restoration
1976 CB750K6
1976 CB750F
1976 GL1000
1968 Suzuki T500 Cobra
1990 BMW K1
2001 'Busa
2003 RC 51
Bunch of Guzzi's
Offline calj737
  • I refuse...
« Reply #76 on: March 24, 2014, 10:25:44 AM »
One difference I note between the 2 restorations is he has been forced to buy some NOS parts as I think they were missing from his project bike. Whereas you've restored them from the original.
Again, not disparaging either project, both are truly beautiful works and extremely talented craftsmen working on them.
Offline dagersh
    • Photos
« Reply #77 on: March 24, 2014, 10:48:26 AM »
Yeah, I am trying not to replace anything that is not a consumable - gaskets and seals not included.
I do have a big order coming in from Western Hills, though....
Dagersh
1962 CA95
1966 Black Bomber
1966 CA77 Dream
1967 Superhawk
1970 CB750K0
1972 CL350
1972 CB500K1
1975 CB550F
1976 CB400F
1976 CB750K6
1976 CB750F
1976 GL1000
1990 BMW K1
2001 'Busa
2003 RC 51
Bunch of Guzzi's
Offline dagersh
    • Photos
Re: 1977 CB550F Restoration - The Rebuild Officially Begins!
« Reply #78 on: March 24, 2014, 12:54:13 PM »
The Rebuild begins!
Not a lot accomplished, but the  engine is ready to go back together.  I wanted a dry run to check everything and then also to make sure I could get the Shift Forks to line up so that the case halves could come back together.
I also realized that in my Powder Coating, I neglected to mask off RH Rear Upper Mount surface where the Ground Strap is Secured, thus Grounding the Engine to the Frame.  A quick hit of the Tan 3M Rocloc on my Die Grinder solved the issue.  Oh, please make sure to wear eye protection AT ALL TIMES!!!!  (Whew, that was close, deadly bits of Powder Coat hurt your face!)
The First piece installed back into the engine is the Starter Reduction Gear making sure to lock the bolt with the Locking tabs on the washer.
Then the Crank.
I wanted to check the clearance of the crank and main bearings, so I went to my local Napa and bought some Green Plastigauge.  Since I did not pull the crank apart and the bike ran strong, I am going to assume if the clearance of the crank and main bearings checked out, I would just leave the Connecting Rods alone.  The bike was 100% out of service due to the horrendous state of the Carbs.
When I went to put the cases together to check clearance, Mr. Murphy found me and pointed out where all the Glass Bead was actually hiding.  It was all in the 8mm Threads in the Upper Case that torque the Crankshaft.  So out came the Metric Tap kit with lots of grease to get that nastiness out of there.
Anyway, long story short, the clearance was all in spec and I am ready to assemble the lower end.
I started back on the uppercase assembling the Shifter Forks and Drum.  The assemblies must be put together inside the case.  The Center Shifter fork as some small bits (the locating pin and clip) so be patient and aware of them.
 As you can see here, I did not do it correctly the first time…  no I did not use the hammer….
Ahhh, much better...  Seriously, make sure the “Long” parts of the shifter fork are facing each other.  And look, no hammer necessary!
I then Attached the Neutral Switch after cleaning up the contact at bit.
Here is the Bearing and Retainer on the other side of the Shift Drum.  Make sure the bearing is flush to the case.
Here is the Shifter Cam assembled on the drum
I then turned to the Lower Case Assemblies.  I had left the Primary Shaft Bearings in the freezer for a few days.  I heated the Lower case where the LH Bearing sits near the Oil Pump and Starter Motor Mount and the Bearing was easily reinstalled.  I then put the Starter Clutch Assembly into its place on the Primary Chain and inserted the Primary Shaft until the RH Bearing was flush with the Case.  I put on the Bearing retainer (Part #2) on the RH side, but left the Top Bolt off as the Shifter Assembly will use the Upper Bolt as a mounting point when the cases are joined.  This is why the Upper Bolt is longer than the lower one – even though the parts diagram shows only the one 6 X 14 bolt (Part #22).  The Longer Bolt is shown on the Shifter Fork/Drum Parts Diagram as Part # 24 (6 X 24)
I then installed the Kick Starter and Shifter Spindles.  I messed up on the Kicker and fortunately was set straight by Dave500.
Here is that discussion:
http://forums.sohc4.net/index.php?topic=135531.0
When Assembling the Kick Starter I found it easiest to use my body (read as Beer Belly) to stabilize the outer part of the shaft where the Kick Arm Attaches so that you can “pull” the Inner Assemblies together in order to get the final washer and 12mm circlip over the end of the shaft.  It’s a pain in the arse, and took up a good majority of my day.  At least I will know how to do it next time…
I then Moved onto installing the Transmission gears.
It is important to note that as you can see from the pictures, I have been replacing the oil seals as I go.
So, now I am ready to dry run the joining of the cases
Upper ready to go:
Lower Ready to go:
I just cleaned up the outer surface of the oil pump of oxidation.  I wanted to leave the cast texture of the rest of it as it gives it more surface area to cool.  When I had the bike running I checked under the tappets for oil flow, and all was very well, so I am leaving well enough alone.
As per some advice, I made sure the gears were in neutral, ie they spin freely.  I then carefully lowered the top case onto the bottom.  It took a few tries but after some massaging I got ‘er done.
Mind you there is no Yamabond here…  I will be doing it again for real this upcoming weekend.  I say this because on my 450 Project I totally forgot to use the Yamabond and had to completely disassemble the completed engine to put it between the cases.  No, seriously, that happened  :-[
Gratuitous Pictures to follow….
Next up, joining the cases and taking apart the frame, wheels and swingarm.
Gersh
1962 CA95
1966 Black Bomber
1966 CA77 Dream
1967 Superhawk
1970 CB750K0
1972 CL350
1972 CB500K1
1975 CB550F
1976 CB400F
1976 CB750K6
1976 CB750F
1976 GL1000
1990 BMW K1
2001 'Busa
2003 RC 51
Bunch of Guzzi's
Offline maduncle
  • Don't confuse me with a
« Reply #79 on: March 24, 2014, 04:53:44 PM »
That big ugly red and yellow BMW keeps getting in the photos and must be in your way.
Just box it up and post it...
CB750K2 (only slightly modified)
Offline dagersh
    • Photos
« Reply #80 on: March 24, 2014, 07:48:52 PM »
It's waiting for you ride it in the Catskills!  Although you did say you wanted the 'Buda this time!
1962 CA95
1966 Black Bomber
1966 CA77 Dream
1967 Superhawk
1970 CB750K0
1972 CL350
1972 CB500K1
1975 CB550F
1976 CB400F
1976 CB750K6
1976 CB750F
1976 GL1000
1990 BMW K1
2001 'Busa
2003 RC 51
Bunch of Guzzi's
Offline maduncle
« Reply #81 on: March 24, 2014, 08:44:52 PM »
Ha!
I'm thinking more 'meet me in San Fran, help me buy a bike and then ride back to your place with me (the long way)'.
Epic coast to coast USA/Aus buddy road trip movie in the making.
Offline dagersh
    • Photos
« Reply #82 on: March 25, 2014, 10:26:10 AM »
I think Beata would kill me....  I still owe her a Honeymoon.....
I know what you are thinking, and she's having none of it....
1962 CA95
1966 Black Bomber
1966 CA77 Dream
1967 Superhawk
1970 CB750K0
1972 CL350
1972 CB500K1
1975 CB550F
1976 CB400F
1976 CB750K6
1976 CB750F
1976 GL1000
1990 BMW K1
2001 'Busa
2003 RC 51
Bunch of Guzzi's
Offline dagersh
    • Photos
« Reply #83 on: March 29, 2014, 06:10:40 AM »
The Cases are joined!  And my cylinder is out for honing, should be ready later on today.
Funny story...  and an example of why you need to completely document your teardown.
So, I was ready to join the cases, had my Yamabond (I know, I am a traitor,,,) applied to the upper case.  I made sure that the gears were in neutral and lined up the shift forks on the top case.
I could not get the cases to line up, no matter how I wiggled and finessed.  I was close to tearing my hair out.
I pulled the upper case back off to try again.  As I was looking at my shift forks I realized I was missing the Transmission Locating pins (#16 in the diagram)
I started tearing through my bagged parts, including the empty glad bags where I had stored the Transmission assemblies.  No joy.  Now I was really pulling my hair out.  How could I lose these?  I was so careful about not letting anything get lost.
I went to my computer thinking that I would have to order them, which meant cleaning the upper case of the rapidly drying Yamabond and waiting another week for delivery - assuming these little guys are even available.  Man, I was steamed!
Then I realized,wait a minute....  when I was powder coating the cases, I had noticed some metal cylindrical pieces at the bottom of the oven....  I thought they were some seird part of the oven, like temp sensors or something, could it be possible?
YES!!!!!!!!!!!!!    8)
Ahhh - crisis averted!
I insterted them in the right place, refreshed the Yamabond and weirdly, everything literally dropped into place with no effort.  Weird, but welcome.
I inserted and tightened up the 6 uppercase bolts and then flipped the engine over to torque the 10 8mm bolts that hold the crank into the case, following the proper sequence.
I torqued them to 17.5 FTLB as the manual gave me range.
I then inserted and tightened the remaining 6mm bolts around the outside of the case.
All said and done, there is a nice, thin and even bead of Yamabond around the case.  I think she's ready to hold oil.
Ready for the top end!
Gratuitous pics:
Gersh
1962 CA95
1966 Black Bomber
1966 CA77 Dream
1967 Superhawk
1970 CB750K0
1972 CL350
1972 CB500K1
1975 CB550F
1976 CB400F
1976 CB750K6
1976 CB750F
1976 GL1000
1990 BMW K1
2001 'Busa
2003 RC 51
Bunch of Guzzi's
« Reply #84 on: March 29, 2014, 06:53:04 AM »
Looks great!
« Reply #85 on: March 29, 2014, 08:10:27 AM »
Nicely done. Glad you found the pins. Much better than ordering new ones and finding the pins AFTER!
Offline dagersh
    • Photos
« Reply #86 on: March 29, 2014, 08:46:56 AM »
Thanks Guys!
Gersh
1962 CA95
1966 Black Bomber
1966 CA77 Dream
1967 Superhawk
1970 CB750K0
1972 CL350
1972 CB500K1
1975 CB550F
1976 CB400F
1976 CB750K6
1976 CB750F
1976 GL1000
1990 BMW K1
2001 'Busa
2003 RC 51
Bunch of Guzzi's
Offline dagersh
    • Photos
« Reply #87 on: November 19, 2014, 04:05:36 PM »
Hi Guys,
Well, I did it again, left a project for months on end...
Unfortunately, my Mom is very ill and I have been the point man on her care, and it has been taking up all my time and energy. Its incredibly frustrating, as its a stage 4 Glioblastoma,  There is only one outcome, which wil be an end to her life and more importantly at this point, her suffering.
To retain/regain my sanity I have been back at the project as I received word that my long awaited chrome will be ready soon. I have disassembled the wheels and plan on PC'ing and relaing them this weekend.  Also, I will be polishing the piston tops and reassembling the top end of the engine and the Carbs,
Pics to follow soon.
Gersh
1962 CA95
1966 Black Bomber
1966 CA77 Dream
1967 Superhawk
1970 CB750K0
1972 CL350
1972 CB500K1
1975 CB550F
1976 CB400F
1976 CB750K6
1976 CB750F
1976 GL1000
1990 BMW K1
2001 'Busa
2003 RC 51
Bunch of Guzzi's
Offline calj737
  • I refuse...
« Reply #88 on: November 19, 2014, 05:20:05 PM »
My heart goes out to you, Gersh. I'm lucky that my mom has come thru swimmingly some recent surgery of her own, but it sure gave me kick in the gut when the news came.
Can't cheat fate, but I sure don't have to go without a fight-
Sending some good thoughts her way!
« Reply #89 on: November 19, 2014, 08:03:23 PM »
And to yours, Cal, too!
Offline maduncle
« Reply #90 on: November 19, 2014, 09:36:20 PM »
Man that's not good at all. I hope that through it all there is some comfort for your mum, and you and your family.
There is always a cold beer and a windy road waiting for you at my house my friend.
Offline dagersh
    • Photos
« Reply #91 on: November 21, 2014, 02:50:10 PM »
Thanks Guys.
Its a real tragedy what's going on as she is 100% aware of what's happening but is paralyzed, aphasic and bedridden.
Madman - I still owe Beata and I that Honeymoon.....
Gersh
1962 CA95
1966 Black Bomber
1966 CA77 Dream
1967 Superhawk
1970 CB750K0
1972 CL350
1972 CB500K1
1975 CB550F
1976 CB400F
1976 CB750K6
1976 CB750F
1976 GL1000
1990 BMW K1
2001 'Busa
2003 RC 51
Bunch of Guzzi's
Offline P.abrera
« Reply #92 on: November 21, 2014, 09:09:53 PM »
Good vibes comin your way from my side of the world
Offline dagersh
    • Photos
« Reply #93 on: December 10, 2014, 11:59:15 AM »
Thanks Man.
1962 CA95
1966 Black Bomber
1966 CA77 Dream
1967 Superhawk
1970 CB750K0
1972 CL350
1972 CB500K1
1975 CB550F
1976 CB400F
1976 CB750K6
1976 CB750F
1976 GL1000
1990 BMW K1
2001 'Busa
2003 RC 51
Bunch of Guzzi's
Offline dagersh
    • Photos
« Reply #94 on: December 10, 2014, 12:33:26 PM »
So, finally some forward progress.
Last weekend I was able to get into the shop and get some powder coating done.
I made sure to strip off the factory clear coat from the wheel  hubs and the rear brake panel.  I then gave them a further cleaning with some soda blast for a little “tooth”.
After that was done, I baked the parts for about 30 minutes at 450 deg.  To outgas anything that might come out during the curing process for the powder.
Once everything was cooled, I masked using tinfoil and heat proof masking tape.  I used the same color as the engine cases, “Silver Speed Metallic” from powderbythepound.com.  I am very happy with its match to the raw aluminum from the factory.
The Rear Wheel
I used the Final Drive flange, covered in tin foil to mask off the outward side to keep powder from getting in to the Drum Brake Lining.  On the other side, I trimmed tinfoil to cover the brake side opening, after I lined the Friction Surface with both foil and heat proof masking tape (sorry, no pics…)  All of this prep also protected the bearing surfaces.
Worked a charm!
The Front Wheel
Again, a mix of foil and tape to protect the bearing surfaces  and some silicone plugs to keep powder out of the Brake Caliper Mounting bolt holes.
Clean!
Last but not least, the Rear Brake Panel.  I used the 2 plugs to keep the steel inserts from getting coated.  I will polish them later on.
Hopefully, I will get them all rebuilt this weekend.
Until then!
Gersh
1962 CA95
1966 Black Bomber
1966 CA77 Dream
1967 Superhawk
1970 CB750K0
1972 CL350
1972 CB500K1
1975 CB550F
1976 CB400F
1976 CB750K6
1976 CB750F
1976 GL1000
1990 BMW K1
2001 'Busa
2003 RC 51
Bunch of Guzzi's
Offline maduncle
« Reply #95 on: December 10, 2014, 03:27:14 PM »
Well that's a bit of nice work there brother - looking very smart.
Offline dagersh
    • Photos
« Reply #96 on: December 12, 2014, 08:19:57 AM »
Gratzie!
How are your wheels?
G
1962 CA95
1966 Black Bomber
1966 CA77 Dream
1967 Superhawk
1970 CB750K0
1972 CL350
1972 CB500K1
1975 CB550F
1976 CB400F
1976 CB750K6
1976 CB750F
1976 GL1000
1990 BMW K1
2001 'Busa
2003 RC 51
Bunch of Guzzi's
Offline dagersh
    • Photos
Re: 1977 CB550F Restoration - I am back, finally
« Reply #97 on: October 06, 2015, 09:13:35 AM »
Alright,
Once again I am back.  Too long, as always. Due to my Mom's sickness, eventual passing and all the craziness that went along with it, I had no desire to work on my projects.
Two weeks ago I got sick of looking at the now dusty tank and frame sitting on my bench, and I gave up on my multiple attempts to get a suitable finish on the PC'd hubs.  I took them along with a couple of other pieces to my place in Poughkeepsie, NY and had them do it.  Of course, I should have done that to begin with, but at least I learned what I can and cannot do with my set up.
They did a great job, and I had a hankering to lace up with the Buchanan's SS spokes and freshly chromed OEM rims from my CB450 build.  Using this post:
http://forums.sohc4.net/index.php/topic,135846.0.html
the fronts literally fell together in 15 minutes.  Seriously, I cannot recommend enough the tips in his post!
I then went on to the rear and hit a snag.  I really had to muscle the inner spokes into the rim.  When I originally ordered the spokes from Buchanan's, they need me to get pictures of the original spokes to them as there are a few different sizes that were used on the 550's (and maybe 500's, I am not sure).  Thinking that I had the wrong size spokes, I called them up to investigate.
They could not have been nicer or more helpful - sorry for the shout out here, but I ordered these spokes a year ago - but we determined that only the rear OUTERS have different specs.  The INNERS are all the same.  He then asked if I PC'd the rims and I said yes.  He suggested the problem is that the coating needs to be cleaned from the spoke holes.  If that does not work, he said to call back an we will figure it out, but he was 95% confident that that was the issue.
So, new question on this extended time build!  If I want to clean out the PC from the spoke holes with a drill bit, what size should I be using to protect from removing any material?
I know I can check against my spokes, but as usual I am in the City and not near the bike and I am obsessing over it....
Alright, I promise pics and description on the next update.
Gersh
1962 CA95
1966 Black Bomber
1966 CA77 Dream
1967 Superhawk
1970 CB750K0
1972 CL350
1972 CB500K1
1975 CB550F
1976 CB400F
1976 CB750K6
1976 CB750F
1976 GL1000
1990 BMW K1
2001 'Busa
2003 RC 51
Bunch of Guzzi's
Offline maduncle
« Reply #98 on: October 07, 2015, 02:41:48 AM »
Aw man - so sad to hear about your mum.
But I am very glad to hear you are still with us here on the forum.
Just so you know, we recently finished off our new outdoor BBQ area at home, so I put on the Sinatra and had a beer (or seven) in your honour.
Now then - nice to see the 550 is coming along. You may have noticed I am now buried in a CB750 build (see my thread) so I am sure we will have much to discuss.
Cliff
Offline dagersh
    • Photos
« Reply #99 on: October 07, 2015, 08:14:28 AM »
If they were not PBR's (Does Australia even allow such dreck to be imported?) I don't want to hear about it!  I thought of you over the summer going through Coxsackie during their garage sale mania!
Thanks man, it was a nightmare year and a half.  I am still dealing with the estate and aftermath, and its never-ending.  However, its good to be coming back out of the funk.
As for the 550, I have all the paintwork done, and its gorgeous.  I just have to step up and get her back together.  I will share pics this weekend.
I will catch up on your 750 ASAP, and I don't think I know how the 500 came out, so I need to catch up on that as well.
Be well Brother!
G
1962 CA95
1966 Black Bomber
1966 CA77 Dream
1967 Superhawk
1970 CB750K0
1972 CL350
1972 CB500K1
1975 CB550F
1976 CB400F
1976 CB750K6
1976 CB750F
1976 GL1000
1990 BMW K1
2001 'Busa
2003 RC 51
Bunch of Guzzi's
