Author Topic: CB750K8, Mystery Carburetor O-Ring!  (Read 1150 times)
Offline Quasirobo
« on: December 28, 2013, 03:16:24 PM »
New here, so hello. So, after a complete tear-down of my CB750K8's Kei-Hin PD carburetors (sounded like fun at the time), I'm going through my little yellow bin of parts and I find a small, very crumbly o-ring that I can't figure out where it came from. It was slightly smaller than the one that goes between the #2 carb body and the float-bowl (for the accelerator pump), but not nearly as tiny as the needle-jet ones...
First off I need to know what size it should be, and/or where I can find a new one. Secondly, I need to know where to put it when I get it. I already bought new needles and gaskets for the float bowls, so I really don't want to buy the rebuild kits for the one little piece (pictures suggest it's sometimes included). I've consulted the fisches, can't seem to find it. Ideas?
Got the ball-valves working, and those darn felt washers replaced, so this is theoretically all that stands in my way of putting this puzzle back together! Much thanks to everyone who has posted tips, diagrams and pics.
Offline harisuluv
Re: CB750K8, Mystery Carburetor O-Ring!
« Reply #1 on: December 28, 2013, 03:18:53 PM »
#2 float bowl accel pump circuit (NOT the valve on the bottom the actual bowl near the bowl gasket surface)
Offline Quasirobo
« Reply #2 on: January 03, 2014, 11:40:14 AM »
The one I'm looking for does not go on the float bowl gasket surface. That o-ring is accounted for. The one I'm looking for is just slightly smaller than that one. Maybe I'm misunderstanding you...
« Reply #3 on: January 03, 2014, 11:46:02 AM »
fuel screw o-ring?
bowl drain screw o-ring?
