Stock honda switch routes 12v to the switch from main fuse, back out of switch to fuse box again for the other fuses. By ganging yours all together the fusebox is pointless, just run a single 15amp main inline off of your solenoid and be done with it.
Additionally, the brown/white is park/acc function. Useless on an MC in my opinion but if you just ganged them they would be hot. So taillight and I thinkkkk front blinkers lit ( I think rear actually.....) You would have your park lights on all the time unnecessarily.
I did the james bond toggle switch on my bike, in fact I have done most of those "cool" mods over the last 2 years. They all seemed cool but in the end they just kinda sucked. Including the car style keyed ignition, I will be getting rid of that soon too
Another thing I just remembered is how the DPST works. What ever you have always on will ALWAYS be on, no matter what (unless you run another toggle to turn that toggle off
![Roll Eyes ::)](http://forums.sohc4.net/Smileys/default/rolleyes.gif)
) and then when the other one is set the other side will always be off. You would have to gang everything together on one side to turn it off which defeats the purpose of a dpst anyway. You can relate how it would function to your starter button. The always on is the headlight. Then you momentarily press it and it sends juice to the start solenoid and no juice to headlight. It is a momentary example but the same thing really
