Author Topic: carbs leaking gas after rebuild  (Read 11345 times)
Offline Jimsun
« on: December 31, 2013, 02:42:43 PM »
Hey guys, after i rebuilt the carbs, I poured gas and all of a sudden, gas leaked from all the tubes. Any ideas? I've read some of the threads and i've measured them to spec height.
74 cb550
Offline LesterPiglet
  • 1977 CB550F2
Re: carbs leaking gas after rebuild
« Reply #1 on: December 31, 2013, 03:04:02 PM »
Did they leak before?
Offline Jimsun
« Reply #2 on: December 31, 2013, 03:54:32 PM »
They did not all leak before. It was only carb 3 that was leaking (a few drops) now it's like a river.
74 cb550
Offline greenjeans
  • 1972 CB750K2
« Reply #3 on: December 31, 2013, 04:15:28 PM »
How did you clean them ?    I've seen the overflow tubes split if they are boiled or cleaned too aggressively.
Other than that, it would have to be the float jets.  Sometimes when they are clean, they don't seal like they used too - the gunk and
varnish that builds up seals pretty good sometimes  ;)
Check your float needles again to make sure that the spring/plunger still works smoothly.
« Reply #4 on: December 31, 2013, 06:13:15 PM »
if this is the first time you've filled them since being dry, just bang on the carb rack with a rubber mallet.  the floats are probably stuck.
if they do not shut off fuel flow, its time to revisit a clean tank, clean fuel, good seating float valves, and properly set float heights.
Offline luap
  • LAWL
« Reply #5 on: December 31, 2013, 08:16:18 PM »
 sounds like you forgot to put the float needle back in before you put the floats back on
75-550 ffsc sold, 78-550 diamonte sold, 125s grasshopper sold, 76-550 puma sold, 78-550 tracker sold, 74-550 verde diablo Sold, 74-550 Noemani finished trying to sell. 72 500 hartail in the works
www.cb-town.com
"I dont need a bike covered in paint an chrome I know exactally bout how big my coc( is"
Offline tlbranth
« Reply #6 on: December 31, 2013, 08:43:27 PM »
Now that's just plain cruel Lu.
Don't own a Vanagon
Don't work at Boeing
Life is good
1970 CB750 K0
1975 GL1000
1999 GL1500
Terry
Offline Ace
« Reply #7 on: December 31, 2013, 09:08:02 PM »
Check that there isn't something like a hair in the needle and seat preventing it from closing. Push the needle closed with your finger, turn the gas on and see if it leaks. If it leaks then it's not seating/sealing properly. If it doesn't leak, then check float height and brass tube for hairline cracks which was mentioned previously. One thing that may have been overlooked is the drain plug screw and o-ring, I'd check that if all else fails.
Float height caused me issues on the last set I rebuilt.
1971 CB750 K1 - Sold
1978 CB750 F2 Supersport - Sold
1981 CB900 Bol d'or - Sold
2006 CBR1100 XX Super Blackbird - Sold
Offline martin_uk
  • CB750F1 CB750K8
« Reply #8 on: January 01, 2014, 05:42:17 AM »
I had the same problem after fitting replacement non OE float valves/seats.
Fitted the original ones and now fine.  :)
CB750F1, CB750K8,  Triumph Street Triple R, AJS 350, Triumph 3TA
Offline jonda500
« Reply #9 on: January 01, 2014, 06:02:32 AM »
my carbs were rebuilt by harisuluv, whenever I hook them up to fuel after they have been dry for some time fuel pisses out every where (except the overflow tubes!!?) but after ten minutes or so they come good and I can leave the fuel tap in the on position all day with no sign of a leak! My theory is that my float hinge pins are so tight that the floats wont move at first but after a few minutes fuel seeps in and lubricates the float hinges. (Oh and yes I realise that I need to check my drain tubes for blockages)
A starter clutch thread:
Offline Jimsun
« Reply #10 on: January 01, 2014, 11:26:32 AM »
Thank you guys,. I will report back after I've inspected and replaced the float needle. Maybe it's the culprit?
Carbs 1,2 and 4 are fine, Carb 3 is still not good. Maybe the float needle wasn't as spongy. I never really kept at eye on this. Just the float height.
74 cb550
Offline tlbranth
« Reply #11 on: January 01, 2014, 11:33:32 AM »
Typical culprits: Hole in float, dirt on needle valve/seat, float hitting posts or side of bowl, dimple in float tang.
Don't own a Vanagon
Life is good
1970 CB750 K0
1975 GL1000
1999 GL1500
Terry
fendersrule
« Reply #12 on: January 01, 2014, 12:11:14 PM »
Hard to believe that I haven't read this yet but:
Make sure to check the bowl casings for cracks from over tightening the valve screw. I found a cracked casing on one of my bowls.
Offline Jimsun
« Reply #13 on: January 02, 2014, 08:09:11 AM »
Ive found out that carb 3 float needle needed replacement. I updated my carb question threadregarding a kit i want to buy. Link below.
The leak is coming from the over flow tube. Meaning the tube at the very bottom of the bowl (?). I have hoses connected to it
http://bit.ly/1l40wHT
Link to my carb question
http://forums.sohc4.net/index.php?topic=132617.0
« Last Edit: January 02, 2014, 08:11:37 AM by Jimsun »
74 cb550
« Reply #14 on: January 02, 2014, 08:16:42 AM »
dont worry, thats where they are supposed to leak so gas doesnt flow onto a hot engine.
do you need the whole kit, or just float valves?  you said you rebuilt the carbs in your first post  ???
« Last Edit: January 02, 2014, 08:20:06 AM by flybox1 »
fendersrule
« Reply #15 on: January 02, 2014, 08:21:45 AM »
Aftermarket carb kits are only good for gaskets (sometimes) and various other minor parts. Usually cleaning up the Honda stuff will yield much better results rather than using carb kit items. For float valves, we don't have a choice.
How did you verify that it was the float valve? A cracked casing will still cause gas to leak out the overflow tube.
Did you remove the bowl and fill it up with water to see if it leaks out the overflow? I'd like to know how you've verified things.
Offline bjatwood
  • I never claimed to be an
  • 1973 CB750-K3
    • Minbikers Proboards
« Reply #16 on: January 02, 2014, 10:04:22 AM »
Could be a crack in the brass standpipe also. These pipes have been known to leak because of these hairline cracks. Something to look for/at when redoing these carbs.
Brian
#24193
I believe that the Finest things are the most thoughtfully made, not the most expensive!
http://minibikers.proboards.com/
Offline Bankerdanny
  • Endeavor to persevere
« Reply #17 on: January 02, 2014, 10:04:38 AM »
+1. Find genuine Honda float needles.
