Author Topic: Teams announced for this years "Phillip Island Classic"  (Read 14763 times)
Re: Teams announced for this years "Phillip Island Classic"
« Reply #125 on: February 04, 2014, 06:38:58 PM »
Oh man, damn shame. Plus side .... nothing is broken to hell!
Offline Tintop
« Reply #126 on: February 04, 2014, 08:12:38 PM »
Huh???  There must be a stuck caliper for that much heat to be generated in a lap Brian.  How much fluid did it piss out the next time you were out?
On the plus side, it's nice with a sidecar to be able to open up the right side of the engine and not lose any oil. ;) ;D ;D ;D
1980 CB750F (project)
77 CB550 Cafe build
550/750 Filter Thread
Sidecar Rebuild Thread
Offline bear
  • Leeton in Australia
« Reply #127 on: February 04, 2014, 10:17:46 PM »
Ah.....
If only that was the case Brent. :-[
The saga is yet to continue. ::)
Brian
Offline bear
« Reply #128 on: February 04, 2014, 10:22:18 PM »
That's the thing Brian. No excess fluid and once at rest for five or ten minutes it was as good as new.
With tape removed from the breather holes, no more problems.
Brian
Offline Tintop
« Reply #129 on: February 05, 2014, 07:38:33 AM »
Weird problem Brian.  Trying to wrap my head around the 'why'.  With the pedal removed there's nothing to create any line pressure, and move the pads.  What your describing is a heat generated vapour lock.  Are the caliper pucks retracting properly??  The disk(s) must be just about glowing red to create that much heat, and fluid expansion.
77 CB550 Cafe build
Offline bear
« Reply #130 on: February 05, 2014, 04:44:18 PM »
No pedal, so I wasn't exerting any pressure.
When the bike was at rest there was no drag on the brake at all, it rolled freely.
When we removed the breather blockage,  no problem.
Brian
Offline bear
« Reply #131 on: February 05, 2014, 05:00:44 PM »
A couple of pictures of the US sidecars.
I wandered down on my scooter to say hello but they didn't seem very intersted in talking to an old codger waddling around on walking sticks, so I left them to it. ;)
Brian, #600 yellow beemer was the quick one.
It doesn't look like the one in photo you posted though.
Brian
« Last Edit: February 05, 2014, 05:05:20 PM by bear »
Offline Tintop
« Reply #132 on: February 05, 2014, 06:25:13 PM »
You should have told them they drove like the Brits play cricket, if they couldn't get by an old guy on sticks. ;) ;D ;D ;D ;D ;D
Interesting re the yellow bike, as it's the same team that ran the green one I posted the picture of.  Must have a new bike.  The Vincent is the one I remember seeing @ Mosport back in 2010.
77 CB550 Cafe build
Offline Tintop
« Reply #133 on: February 06, 2014, 04:53:20 AM »
Re brake lockup issue Brian.  Only thing I can think of is you have a disk(s) that is/are running out of true.  It would be trying to push the piston back.  However, because of the sealed breather (no vent to atmosphere) this would prevent pressure release.  So the continual pulsing would instead build pressure until it locked.   Once parked the pressure would slowly normalize, releasing the brakes.  my .02
77 CB550 Cafe build
Offline bear
« Reply #134 on: February 06, 2014, 03:26:17 PM »
I will check it out on the weekend and let you know.
Brian
Offline bear
« Reply #135 on: February 12, 2014, 05:07:47 AM »
Stripped the motor down to pull it tonight but it was just to hot for me 41 degC again. :-[
Did find this in the sump though, so I know exactly what I'm going to find.
This is what happens when you try to run 125rwhp through a std box. >:(
The thing is I know better. :o
It's very hard to self administer an arse kicking but I will give it my best shot.
Then I'll install a HD box as I should have in the first place. :-[
Brian
« Last Edit: February 12, 2014, 11:53:58 PM by bear »
Offline Bill/BentON Racing
    • BentON Racing
« Reply #136 on: February 12, 2014, 05:18:38 AM »
That dog won't hunt no more! ;D
BentON Racing Website
BentON Racing Facebook
Offline kmb69
« Reply #137 on: February 12, 2014, 05:38:13 AM »
Brian
Brian, Who sells a HD box or where would one find such? Keith
Offline bear
« Reply #138 on: February 12, 2014, 05:47:45 AM »
Your right there Billy, took the woof right out of it.
Did you check it out? No wear, just ripped them clean off.
My own silly fault, oh well. ::)
Brian
Offline bear
« Reply #139 on: February 12, 2014, 06:00:24 AM »
Brian
There are couple of options Keith.
The Poms have a mob called Nova in England.
But I use heavy duty gears made in Melbourne down here for Rexy Wolfenden.
Brian
    • BentON Racing
« Reply #140 on: February 12, 2014, 06:10:59 AM »
Haha, I knew Rexy would be involved. So not speaking for Keith, bit I believe we may both be in need? Which gears are available and what to you do to to achieve. H/D setup....besides $$$$! Bill had a Nova for short while, they're pretty pricey!
Offline kmb69
« Reply #141 on: February 12, 2014, 06:16:12 AM »
Glomming on ... And is it a close ratio or standard gearing?
Thanks, Keith
Offline bear
« Reply #142 on: February 12, 2014, 11:53:01 PM »
Thanks, Keith
Pommy version is C/R
Ozzy version is std
Brian
« Reply #143 on: February 12, 2014, 11:57:15 PM »
How much are the full gear sets from Rex Brian..?
Offline simon#42
  • liverpool
« Reply #144 on: February 13, 2014, 08:52:09 AM »
not sure about the aussie version but have just bought a nova box for an air cooled bmw twin and it was £1500 i expect the 750 box will be similar money .
go on mick get your money out ............... again !
Offline bear
« Reply #145 on: February 13, 2014, 02:14:34 PM »
I only use second third and fourth Mick.
They set me back $1100 in 2009.
I've got a mate of a mate who cuts gears, reckons he can do them, I'll check him out.
Brian
« Last Edit: February 13, 2014, 02:19:40 PM by bear »
« Reply #146 on: February 13, 2014, 02:38:25 PM »
Brian
Thanks Brian, keep us posted mate.... ;)
Thank god your not my manager.... :o ;D
Offline Tintop
« Reply #147 on: February 13, 2014, 06:36:51 PM »
Current price for a Nova CB750 CR gear set is ~$2500+ Aus (1365 UK). :o
77 CB550 Cafe build
Offline simon#42
  • liverpool
« Reply #148 on: February 14, 2014, 01:13:20 PM »
ah plus vat at 20% if you live in the peoples republic of europe  making it £1638.00
Offline Tintop
« Reply #149 on: February 14, 2014, 07:29:26 PM »
 ;D ;D ;D ;D ;D ;D ;D
Don't have one of those GBP things on my keyboard, but then I'd paying the exchange rate (1GBP=$1.86Cdn :() + duty + tax + shipping.
77 CB550 Cafe build
