Author Topic: Best advice on repainting a frame? plus a few related questions.  (Read 7719 times)
Re: Best advice on repainting a frame? plus a few related questions.
« Reply #25 on: January 04, 2014, 01:23:59 PM »
So, is a "Mil", a "Millimeter" mate? I've yet to see powdercoat 2-3 Millimeters thick? And "Micron" is still common parlance here in Oz when talking about the thickness of paint. Cheers, Terry. ;D
Offline Bru-tom
« Reply #26 on: January 04, 2014, 01:27:10 PM »
after googling the "mil":  A mil equals 1/1000 of an inch
more here: http://www.autopia.org/forum/topic/122930-paint-thickness-gauge-ptg/
micron is used where the most accuracy is required.
« Reply #27 on: January 04, 2014, 01:32:47 PM »
Ah, that makes sense mate, I painted cars for many years, and while "Micron" is common in Automotive paint discussion, I'd never heard of a "Mil" before. Cheers, Terry. ;D
Offline Powderman
« Reply #28 on: January 04, 2014, 08:43:23 PM »
How many microns are you talking about for paint? As mentioned a mil is .001. 3 mil, or .003" of powder would be 685microns. Are microns there the same as they are in the rest of the world?
Offline greenjeans
  • 1972 CB750K2
« Reply #29 on: January 06, 2014, 07:05:19 AM »
I've powdercoated at least 5 frames over the years.  A good powdercoater will have many different "blacks" to choose from.   I've always done a shade that is between gloss and satin - closer to satin.   I've yet to have any problems with the finish.  Purists have yet to be able to tell the difference on my restos.   I always tell the powdercoater that is is going to be a "show" bike and I usually clean up the welds and splatter a little before handing it off.
I should also add that I leave a 12 pack of fancy beer for the guys doing the work.  Bribery goes a long way.
Now, I have seen some truly horrific powdercoating jobs - as with anything, it comes down to the preparation and the skill of the person doing the coating.
Also - they say you can not polish powdercoat.   You can, but it is a bit harder than paint.
Offline Powderman
« Reply #30 on: January 06, 2014, 09:11:34 AM »
Actually I have found it to be no harder than polishing paint. It's done the exact same way, sanding till you get to 2000grit and then buffing and polishing.
Paccar black is a 55% gloss  black and what is standard in the automotive business for frames and chassis parts .
« Reply #31 on: January 06, 2014, 10:31:18 PM »
Ha ha, "Microns" aren't an "American origin" unit of measurement mate, so hopefully they are the same for the rest of the world. (Including America............) ;D
Offline Powderman
« Reply #32 on: January 07, 2014, 08:27:34 AM »
So my question remains, if your automotive paint jobs are measured in microns , how many microns thick is one?
Offline Bru-tom
« Reply #33 on: January 07, 2014, 09:10:06 AM »
that question seems a little demeaning to me. because if you dont know how thick standard paint should be, youre fooling a lot of people  :P  there is a simple conversion from the unit of measurement we use to yours. I am no professional spray painter and that is jargon to me still. But i am no idiot when it comes to spray painting. The thickness does not matter to me when i paint nor do i have a device to measure it. When i bought paint for my tank, the dude says ave should be around 30 micron for primer depending on how many coats you give it, the base and clear another 80-90 odd. So total will be around 110-120 microns, also depends how many clear coats you apply. Which converted is about  4 1/2 to 5 of your mils.
but you already know this :o
« Last Edit: January 07, 2014, 09:12:02 AM by Bru-tom »
Offline Peter K
« Reply #34 on: January 10, 2014, 01:02:52 AM »
Terry, Fantastic pictures, looks really good.
In the end think that I will paint it rather than powder coat. I suppose that the mils will be whatever they work out to when I've finished. I don't have all the parts here until June so unless I get too impatient won't do it until then. Chances are that I will be too impatient, but can't do anything anyway for the next month or so, but will let you know.
I was surprised that most people didn't say remove the plate and put it back afterwards.
"you don't know what you don't know, but someone else probably does"
« Reply #35 on: January 10, 2014, 01:06:38 PM »
G'Day Peter, no worries, the reason I haven't suggested to remove the VIN tag is that it used to be illegal to remove a VIN tag and may still be in Victoria as this was commonly done when vehicles were stolen and "Rebirthed". (a VIN tag off a stolen vehicle was removed and replaced with one from a written off vehicle)
I don't know if that's still the case though, so it's probably best to call Vicroads before you do so. Cheers, Terry. ;D
