Author Topic: "The Basement Build!" 1973 Cb350F  (Read 68109 times)
Offline 2strokeTrush
  • Can you get that back together sonny?
Re: "The Basement Build!" 1973 Cb350F
« Reply #175 on: March 12, 2014, 08:55:59 PM »
Got to work draining the Oil and removing the Clutch Cover.  Cut a hole in the table and the oil drained right through!
Super Helpful tip from the site. Im a country boy, not an Artist. don't judge!   :D
Cant say I really know what a clutch is supposed to look like, but it seems to be ok in there.
There is some sort of sludge in the bottom of the cover, ill have to get it out.
Well this has seen better days, undecided if i want to paint just the "Honda" or paint around it and leave that alone.
Parts waiting to be prepped and high temp painted.
« Last Edit: March 13, 2014, 06:21:03 AM by 2strokeTRush »
If You Aint First Your Last!!
 350F project-http://forums.sohc4.net/index.php?topic=133079.0
500F Project-http://forums.sohc4.net/index.php?topic=135660.0
« Reply #176 on: March 14, 2014, 05:06:29 AM »
If there is sludge, you may want to pull the oil pan and clean that too.
« Reply #177 on: March 14, 2014, 06:08:36 AM »
Isn't that a pretty complicated process?
« Reply #178 on: March 14, 2014, 06:38:34 AM »
No, it's just a cover with 10-12 bolts, same as the clutch cover. You will need a new gasket of course. You may be surprised on whats in there?
Don't be afraid, we're here for you!
I'll be doing the same to my 750 this weekend.
« Reply #179 on: March 14, 2014, 07:15:39 AM »
I hope you find a person to patch/braze some sheet metal onto your header pipes.They run SO much better w/ the stock pipes in the low-mid range rpms.
« Reply #180 on: March 14, 2014, 09:22:48 AM »
Thanks for the heads up, I will probably just wait till I have the bike back together because i can't get to the bolts on the table.  Where is a good place for gaskets? I don't want a cheap one that leaks! And i assume clean the pump as well?
I hope you find a person to patch/braze some sheet metal onto your header pipes. They run SO much better w/ the stock pipes in the low-mid range rpms.
I actually have a really good welder who has welded his entire life and he said he would give it a shot.  If not I saw a post about someone who filled his holes with JB Weld and spray painted silver over it.
Offline dagersh
    • Photos
« Reply #181 on: March 14, 2014, 09:28:36 AM »
2Stroke,
Honda or Vesrah for the gaskets.
Gersh
1962 CA95
1966 Black Bomber
1966 CA77 Dream
1967 Superhawk
1970 CB750K0
1972 CL350
1972 CB450/500 Custom
1972 CB500K1
1975 CB550F
1976 CB400F
1975 CB750 Future Restoration
1976 CB750K6
1976 CB750F
1976 GL1000
1968 Suzuki T500 Cobra
1990 BMW K1
2001 'Busa
2003 RC 51
Bunch of Guzzi's
« Reply #182 on: March 14, 2014, 10:01:21 AM »
2 stroke,
     I used only the method of brazing good quality sheet metal onto the exhaust.JBweld or similar muffler patch putty will blow out.The areas you have that are rusty,is it at the bottom of the head pipes ? I know it'll be a good thing to braze some pre-bent pieces of steel onto there and make it overlap the holes a little;after you've prepped it,you're friend will need you to hold each piece down while he tacks it.Braze will completely seal those areas and strengthen the pipe and it'll last for the life of the bike.
« Reply #183 on: March 15, 2014, 04:03:56 PM »
2Stroke,
Gersh
Would they have clutch cover gaskets that are good as well?
« Reply #184 on: March 15, 2014, 04:11:48 PM »
Used most of today up painting, sanding, stripping, prep work, and more and more painting.  Also Painted the side sprocket cover, stator cover, rear brake, and the exhaust flanges.  Il post picture of them later after i check on the curing and how well the high temp paint has set.   But here is a few of today, and a question I am a little worried about.
Soaked these puppies in a chemical mixture I made up and removed all the rust from them.  Almost to good to paint!
Started to strip before paint.
Heres the question, I was beginning to start prep on the clutch cover when I notice the gasket is bent,  Not wanting to risk it i tried to take it off, but it literally crumbled and parts of it are still stuck to the cover, so the new one isn't going to sit flush.
Heres what came off, but the rest is stuck good on there! SOMEONE PLEASE HAVE A TRICK FOR THIS!
« Reply #185 on: March 15, 2014, 04:34:10 PM »
2 stroke,
  Vesrah is Good quality gaskets man;they'll sell you the complete gasket kit for the whole engine.I bought mine off of ebay from a seller named "motorcycle solutions" Local shops should be able to order it for you also.
I regularly use a one-sided razor blade to clean gaskets off of the covers,be careful about digging into the aluminum though,it'll take persistant patience.They also have a gasket remover spray chemical you can use to soften the gaskets before scraping them off,I usually do it w/o that though because that stuff'll get underneath your fingernails & it's strong acid.
Nice Job on those finned exhaust clamps !
Offline jason405
« Reply #186 on: March 15, 2014, 04:59:20 PM »
What is this chemical rust removal elixir you speak of?
« Reply #187 on: March 15, 2014, 05:07:17 PM »
Yes enlighten us about that chemical cocktail.
« Reply #188 on: March 15, 2014, 06:58:43 PM »
I buy my gaskets on eBay too.  A sharp chisel and beer will remove the old gasket.
« Reply #189 on: March 15, 2014, 09:12:30 PM »
Little bit of Phosphoric Acid, Vinegar as your neutral control, Hydrochloric Acid used with some rice to keep moister and prevent flash rusting, and some heated Nitric Acid in a Polyurethane Tub because they won't break down. SCIENCE!!  ;D Please don't go mixing this stuff in your kitchen though guys!
If I were to soak the bottom of the cover where the gasket is stuck in some WD40 would that soften it up??
« Reply #190 on: March 15, 2014, 09:18:01 PM »
brush a little paint remover on it.
« Reply #191 on: March 15, 2014, 09:18:57 PM »
thanks ill give that a try tomorrow!
« Reply #192 on: March 16, 2014, 07:51:26 AM »
Sounds like a Breaking Bad recipe!
« Reply #193 on: March 16, 2014, 08:20:51 AM »
No Bull,could you send me the complete recipe w/ the correct ratio's per each ingredient  and how much to heat ? I'm not a Science major or anything so if you could break it down for me as a blue collar worker guy.I'd LOVE to get my exhaust diffusers looking like that  ;D How does that mix leave the finish of the chrome,still shiny ?
                 Bill
« Reply #194 on: March 16, 2014, 08:53:50 AM »
                 Bill
Yes please post it.
« Reply #195 on: March 16, 2014, 11:55:21 AM »
OK the mixture isn't super super perfect, it changes on what type of metal because of how quick the covalent bonds will break down the components.  This is what I ran by my chemistry teacher and he advised me to be careful not to add more then this:
2oz of Phosphoric Acid first.
Mix 1oz of Vinegar in with a wooden peg.
OK now make some ready rice in the microwave and add a little water, because this will stop the flash rust issue. Then 1oz Hydrochloric Acid and make a "mash" and add that in.   Heat up some Nitric Acid OUTSIDE to about 95 and let it cool to about 80 and mix it in.  In your poly tub drop your flanges in and shake the crap out of it.  Let it sit 24 hours and wash em off.  Wear gloves! and be careful.  After you strip them mine have come out shiny I'm not sure what happens to the metal but this has worked twice for mine!  I wouldn't recommend this for other parts as I'm not sure what would happen.
« Reply #196 on: March 16, 2014, 12:14:16 PM »
Does the chrome still shine ? show a pic.
« Reply #197 on: March 16, 2014, 12:29:47 PM »
I just Painted them. but yes it shined!
« Reply #198 on: March 16, 2014, 12:48:28 PM »
I was thinking of doing that chemical bath treatment as you've described and then using High heat silver I'd spray some into a cap and then paint only the parts that're bare metal;I'd polish the paint back toward the chrome just a little w/ fine steel wool.
But that's just me,if I had the $ I'd rechrome it All.  ::)
« Reply #199 on: March 16, 2014, 01:08:03 PM »
Your idea seems like it would work just fine, but for me it was mostly to remove impurities and rust so the paint would seal correctly. Im pretty sure these will get the most heat being right on the exhaust head.
