Author Topic: honda 550 big bore pistons 61mm HC pistons in a stock bore 750?  (Read 8043 times)
Offline hondaman750
  • The value of life can be measured by how many times your soul has been deeply stirred.
« on: January 04, 2014, 05:19:17 PM »
has anybody ever put 61mm high compression pistons from a cb550 big bore kit into a cb750 stock bore ? i would like to try and get some feedback has anybody ever done it ? im wanting to leave my K8 stock bore but get a good bit more power out of it if possible mainly because of the lack of funds and lack of reputable machinists in my area and help would be great!
Don't let the little red bar on the tach stop you from reaching 12k they love it! Mine does
Offline BPellerine
Re: honda 550 big bore pistons 61mm HC pistons in a stock bore 750?
« Reply #1 on: January 04, 2014, 05:47:10 PM »
check to see if f2/f3 pistons will fit not sure myself but they are higher comp.bill
1978 CB 750K ard and webers
another anfob
« Reply #2 on: January 04, 2014, 06:01:45 PM »
Subscribed: this is an interesting possibility! If you have the 550/61mm pistons, stick a wrist pin into one, then also into a 750 piston, to see how the crowns and skirts match up. The Gentleman's Express 550 conversion uses these the other way 'round...
Offline hondaman750
« Reply #3 on: January 04, 2014, 06:03:27 PM »
thats what i was thinking people are using 750 pistons in their 550s why would the 592cc kit work in a 750 they are both 61mm
Offline hondaman750
« Reply #4 on: January 04, 2014, 06:05:34 PM »
   the only problem is i dont have any 550 pistons laying around or know anybody with one :/ in theory i would think that it would work
« Reply #5 on: January 04, 2014, 06:09:07 PM »
I have been getting a bunch of e-mails lately about a 61.5mm big-bore piston kit for the 550 that is $120 on eBay, from the same folks who make the nice 836cc low-compression piston kits. These work well in the street bikes I've built with them, so I suspect the 550 pistons would work, if the crowns and skirts will fit. This would also allow some "bore room" of .5mm for the post-1975 F engines that could then receive a stock-ish bore size, with high-dome pistons.
Hmm...might have to hazard a set?
Offline hondaman750
« Reply #6 on: January 04, 2014, 06:10:06 PM »
Maybe worth a try
Offline hondaman750
« Reply #7 on: January 04, 2014, 07:34:43 PM »
The only thing I can think of being different is the valve reliefs in the piston maybe the 550 ones are smaller?
« Reply #8 on: January 04, 2014, 08:21:33 PM »
That's what I was thinking, easy to solve, though. :)
Offline classic bike tuner
  • http://www.cmrch.nl/
    • cmrch.nl/
« Reply #9 on: January 05, 2014, 03:01:23 AM »
the 550 biggbore pistons are stock dimensions exept bore  so flat top
and the 550 pistons have a lower pin-crown height than 750 pistons
with 550 - 61,5mm biggbore pistons  in your 750 you have lower compression
if u use 750 F2 you end up to high [1-14 ]
Offline hondaman750
« Reply #10 on: January 05, 2014, 10:07:07 AM »
On the other hand does anybody know of a place a can find stock bore  high compression pistons about 11.5.1 or so?
Offline 750essess
  • Orleans Cycle Repair & Resto
« Reply #11 on: January 05, 2014, 12:20:30 PM »
M3 racing has 62mm wiseco's on their site. Doesn't say compression.
http://www.m3racing.com/products/parts.html#CB750
Orleans Cycle Repair and Restoration
76CB750F
69Z50
XR650L
    • cmrch.nl/
« Reply #12 on: January 06, 2014, 03:55:12 AM »
u can use boldor rods  these are 1mm longer than stock 750  and are a bit stronger too need to machine piston for good squis area [ 0,8mm ]and meybe valve pockets
if your stock compression is 9,0 you end up 10,2 with bol rods
Offline hondaman750
« Reply #13 on: January 06, 2014, 08:25:25 AM »
Is anybody out there running f pistons with a k head?
Offline EnginebyAdam
« Reply #14 on: January 06, 2014, 08:28:46 AM »
If you were to use cb900 rods there are a few things to look at. The cb900 rods are considered weaker than the cb750 dohc rods, but it is all a matter of opinion. The moderator on the cb750 custom site ran NOS on his stock bottom end cb900 with no problems. I shot peened my cb900 rods and have confidence in them.
The one must do upgrade for the cb900 rods is to replace the stock rod bolts with cb1100F rod bolts. The stock cb900 rod bolts have a spiral pattern in the bolt, and have failed.
Better Rodded Than Rotten
Offline BPellerine
« Reply #15 on: January 06, 2014, 10:02:36 AM »
I think the 78k head has a little bigger chamber than earlier so maybe not so high compression .you could use a thicker head gasket or thicker base gasket to lower it some if you want.would be a budget way but don't know about the power increase.you could drop in the f3 cam if you have the clearance .any of the head experts should be able to tell you if it is poss.bill
another anfob
Offline hondaman750
« Reply #16 on: January 06, 2014, 10:04:18 AM »
I'm already running  #41 grind webcam I'm just looking for more compression
Offline BPellerine
« Reply #17 on: January 06, 2014, 12:34:39 PM »
well I guess you could research the f2/3 option.bill
another anfob
Offline hondaman750
« Reply #18 on: January 19, 2014, 06:31:49 PM »
Anybody else have any ideas? on how to bump up CR on a stock bore bike maybe milling down the head a little bit?
Offline hondaman750
« Reply #19 on: March 19, 2014, 06:16:32 PM »
does anybody happen to have a 550 piston laying around that they could donate? for scientific reasons of course doesnt even need to be good could be from a blown bike as long as it can have measurements taken
Offline twatermelon
« Reply #20 on: March 22, 2014, 03:36:56 PM »
A stock or 61mm piston? What measurements do you need?
Offline hondaman750
« Reply #21 on: March 22, 2014, 03:42:52 PM »
Looking for wrist pin to crown and wrist pin to skirt and such
« Reply #22 on: March 22, 2014, 08:00:24 PM »
Here's a pic of a 750 (std #300) piston vs 550. The difference is dramatic. The CB550 61mm big bore pistons compression height is nearly identical to the stock 550 piston.
I can send you a CB500 piston if it helps. The only difference is 56 vs 58.5mm for the 550. Otherwise they share exactly the same dimensions.
« Last Edit: March 22, 2014, 08:02:40 PM by bwaller »
Offline hondaman750
« Reply #23 on: March 22, 2014, 08:04:00 PM »
Then I wouldn't really gain anything on CR then
« Reply #24 on: March 23, 2014, 01:15:23 AM »
Good info! I have a set of CB900 DOHC rods for future project. 900CC cylinder that I might bore and buy newer 915cc pistons instead of old flat Henry Abe 67.5mm pistons.
About the lenght. I double checked my rods in the garage. CB900 DOHC rods are 1.5mm longer than CB750 SOHC. I saw the strange bolts too.
Fine tuning the CR with gaskets. I purchased an 836cc head gasket from Yamiya. This is 0.5mm  thicker than the Cometic fiber gasket.
Edit:
Note! The bearings are still in the 900 rods
« Last Edit: March 24, 2014, 04:33:52 AM by PeWe »
