I bought it as a non runner but I pulled the motor, changed the piston rings, changed the valve seats, replaced the points with a pamco ignition, replaced the coils, replaced the wires, replaced the plugs, replaced the harness, replaced all the electrical... literally everything on this bike is brand new. The carbs were done by a member on this site. And I've ran fuel through them plenty of times to confirm everything is good and flowing
I would love to do a vacuum carb sync but the bike wont even idle and I cannot do the timing properly because it wont idle. I have it set at the starting point for the pamco which should allow it to run....
