Kghost,
I'm sorry if I misspoke. I was under the impression that '69=K0, '70=K1, '71=K2 and '72=K3. Apparently that is not the case? Mine was manufactured in 09/1972. Could I beg you to measure the distance between the shock mount hole and fender mount hole on your bar? Your picture leads me to believe that the rear hole on the bar you have lines up with the bolts holding the fender on.
Dusterdude,
Scrapping the turn signals really doesn't appeal to me as people have a tendency towards rear-end collisions here in Oregon. Not sure why, but I would prefer that they have a turn signal AND brake light to help them see me when I am stopped.
Anyway, for now I have just bagged the seat rail (I think it is the wrong one, as the rear hole you see extends well beyond the existing fender mount bolt) and fabbed up a mounting tab to bolt into the rear fender mount bolt behind and below the seat.
Thank you all again for all your help. This site, and the community of SOHC4 enthusiasts that make it work, is an absolute Godsend!
Tim
